I am trying to find an annoying dash rattle and silence it. It may be under the gauge pod. I cannot figure out how to easily remove it and I do not want to break it by forcing it. Any help? Thank you
more info It is a factory (dealer installed) pod up on top of the dash where the clock is supposed to be. I found one rattle. The plastic trim around the steering column. M-
It should snap in, in four places. Use a flat head screw driver wrapped in electrical tape to pry it up gently if you prefer.
