FUCK Started while I was in asheville this weekend and I had to drive back. Going to call Classic in a few and schedule something up. Anyone else had this issue?
the dccd trouble code could be pulled by the following procedure: engage parking brake turn ignition to on set dccd to min fully depress throttle turn dccd dial fully to max, then back to min. repeat this 10 times It will flash 2x/sec if there is no trouble code If there is a trouble code, a 1.2 s flash indicates a 10 digit, and a .2s flash is a 1 digit. So 1.2, 1.2, .2, .2 would be a 22 diagnostic procedure: 1: engage parking brake 2: set dial to min 3: start engine 4: set dial to max 5: release parking brake 6: set dial to min 7: engage parking brake 8: repeat 4-7 twice in 30 seconds (will now get a trouble code display) 9: operate parking brake 10: operate brake pedal 11: operate manual mode 12: operate dial and set to max, wait 3 seconds 13: drive above 10mph for at least 5 seconds and check the indicator status light At this point if the system is happy the next ignition cycle will clear the dccd trouble code There are only 7 dccd codes, 11, 12, 13,14, 21, 22, 23. Rear diff sensor is not a trouble code, just an override condition that will clear as soon as temp is ok.
when I first had mine it did it once or twice when I was still getting used to the hill start assist (starting from a light it would just sometimes start flashing, can't even recall what I was doing to cause it). Probably doesn't help as mine turned off once I turned off/restarted car. I'm assuming yours is still on?
