DD Suspension
Discussion in 'Modifications & DIY how-to' started by WRXCoupe, Feb 22, 2009.
  1. WRXCoupe
    WRXCoupe Active Member
    Trying to put together a slightly more aggressive budget friendly DD suspension for my 02wrx. I picked up a complete set of used 05 Sti strut assembly's front and rear: struts/springs/top hat's. The whole set up has 15k so very low mileage. I need to swap out the front struts with something compatible for the rest of the set up since the 05 Sti struts will not bolt on to the 02wrx knuckle assembly. I am thinking about 04 oem Sti struts. Any suggestions would be appreciated, (Big sways and end links are in the works as well).
  2. goixiz
    goixiz Active Member
    or you can contact me
    and i can give you a list of items that you can buy off the shelf to convert it to fit
  3. Cool_____
    I LOVE my new DD suspension. RCE Blacks with Tokico DSpec struts. I got the extenders so I can adjust the rears without having to take out the back seat.
  4. WRXCoupe
    Sounds nice!
  5. Cool_____
    I love it. I have pics I need to upload soon and will in my thread.
  6. WRXCoupe
    :bigthumb:
  7. yerrow
    yerrow Active Member
    I can attest to the dspecs also. Virually silent, easy adjustments, good control
  8. SubiNoobi
    SubiNoobi Supporting Member
    If you don't have a wagon, D-specs seem to be THE best reasonably priced solution. I would have them on my car as well, if it were a sedan....
  9. yerrow
    Uhhh I have dspecs on my waguhn
  10. Davidwrx
    Davidwrx Member
    The trick to sedan struts on the wagon is the loss of some camber. Camber bolts fix that though.
    The wagon solution is Koni inserts in wagon strut bodies.
    Back to topic - for budget, I think the STI springs are good. Struts and sways, and rear endlinks are the next step.
