Power Mods: helix 860cc injectors, Walboro fuel pump, RPS Turbo Max Clutch, Perrin FMIC, 3" turbo back exhaust with no cats, SMC meth inj, Tial 50mm BOV and 44mm WG, and an SZ60 from Deadbolt , 6gun oil cooler kit, one step colder plugs, Perrin Big Maf, Topspeed Ecutek, EWG uppipe fabrication, and TGV delete. Run was made at 28psi holding to redline, on pumpgas with meth injection, at the end of the run we were seeing maf voltages of 4.82v. The turbo had more in it but we ran a smaller spring for a poor man's "map switch". I can shut the boost and meth control off and run 8 psi on pump which makes 285 whp. By varying boost I vary the hp pretty well. On pump gas and meth we made: 330whp at 13 psi 365whp at 16 psi 425whp at 21 psi 465whp at 24 psi all with very conservative timing and AFRs. Many thanks to TopSpeed, Deadbolt, and 5Zigen for helping make my timetrial project come together. For some interesting comparisons to rotate kits check out the other graphs here: http://forums.nasioc.com/forums/showthread.php?p=13658129#post13658129
lol, I'm your huckleberry. Thanks for the kind words guys... Should have some pics up this weekend of the wheels, stickers, and turbo setup.
Thanks guys. It has been pretty fun. After playing with the 500 whp map; I spent the weekend at 'only' 420whp...
