Does my Log look OK?
Discussion in 'Modifications & DIY how-to' started by LoveMyNewSoob, Apr 25, 2015.
  1. LoveMyNewSoob
    LoveMyNewSoob Member
    Hey everyone,
    I catalogued the other day getting onto 75, but am not entirely sure what to look for in the numbers. Would someone be willing to lend a hand here?
    I've attached the zip file.
    Thanks,
  2. Drowland87
    Drowland87 Staff Member Supporting Member
    [youtube]rjEGZ-4dsDY[/youtube]
  3. LoveMyNewSoob
    Thanks. My A/F learning doesn't seem to change. Is that ok?
  4. Drowland87
  5. LoveMyNewSoob
    Thank you. Boost looked to be high too, so I am going to try the low wastegate map.
  6. Drowland87
    If that is a OTS stage 2 then you are definitely getting boost creep (you peaked at almost 21 psi). Loading a low wastegate map would be a great idea.
  7. Drowland87
    After you switch drive around until your DAM goes to 1 and then do a 4th gear log and post it.
  8. Drowland87
    Just be careful doing so. 4th gear tops out at around 104ish and it's the end of the month, as in quota time for the boys in blue.
  9. LoveMyNewSoob
    Yeah, it is an OTS map. Switched it to the low wastegate yesterday. There is not a lot of places around me to do these pulls, so it might be a while until i can get another log.
    Thanks for the info!
  10. Drowland87
    No problem.
  11. LoveMyNewSoob
    I might try to get one this weekend. The car does seem to be accelerating a lot smoother. Coincidence? Or, just the new tune? I guess we will see!
  12. LoveMyNewSoob
    So, I was able to get another pull in over the weekend. Log attached
    Any feedback is much appreciated.
  13. Drowland87
    Much better on the low wastegate map! That's what boost should look like on a OTS stage 2. Everything else looked as they should as well. I'm no expert but, it looks good to me. Someone else chime in if you see something I missed.
  14. LoveMyNewSoob
    Thanks for the feedback. The car definitely feels healthier and happier. It's a bit smoother on acceleration now. Even during normal driving
