Door Lock Issues
Discussion in 'Modifications & DIY how-to' started by nygiant, May 17, 2014.
  1. nygiant
    nygiant Member
    I've been having issues with the powerlocks for the the drivers side front and rear locks. Please see the video to see my issue.
    While I don't have anywhere as extensive automotive repair knowledge as some of the folks on this board, I would like to fix this issue myself. Suggestions on what I should look at first?
    Thanks
    [youtube]cDNVZFs45Gk[/youtube]
  2. b reel
    have you pulled your door panels off in the past? there is a plastic clip that is more or less a pivot for the rods, check to see if those are broken. I had a similar problem with my wagons rear doors and it was the plastic clip.
  3. nygiant
    nygiant Member
    The panels haven't been pulled off before, but I will give it a look. Thank you sir
  4. b reel
    do the levers move at all? try to move? if so then it may the plastic clips if not then check the other door lock button. If it works the locks then you know the drivers side switch is the problem
