dp install question
Discussion in 'Modifications & DIY how-to' started by Dheim96, Aug 9, 2013.
  1. Dheim96
    Dheim96 Member
    Does taking the intercooler off make that big of a difference when changing the dp? Or is it more work than worth it?
  2. SonicBoom
    SonicBoom Active Member
    I would try with it in... only take it out if you have to.
  3. b reel
    removal may speed up the process if still has factory cooling tin in place.
  4. Sparta
    unless you have a really long extension and a swivel socket you won't be able to reach a couple of the bolts and even then it'd have to be from the bottom. Don't be lazy, take it off. its only a couple of clamps, Try and get the clamp to the BPV off rather than unbolting it and risk ruining the gasket or stripping the 2 bolts hold it in.
  5. Dheim96
    Dheim96 Member
    I'll just take it off. Thanks for the replies.
  6. Dheim96
    Dheim96 Member
    Is there an easy way to get the bolts with the spring back on? Seems like they wont go back like the spring is streached to far.
  7. Dheim96
    Dheim96 Member
    I need a Local place to longer bolts for the dp to cbe. Anyone know of a place that is open still?
  8. integroid
    Ace hardware...Make sure it is a higher grade SS.
