E- brake light on
Discussion in 'Modifications & DIY how-to' started by jayjaysti, Dec 17, 2007.
  1. jayjaysti
    jayjaysti Member
    for some reason when i hit full bosst 1.1 bar the E-brake light comes on, can someone help me out
  2. FACE
    hummm
    Does it go back off when you come out of boost?
  3. Matt
    if it turns on when suddenly speeding up or slowing down, it means the rear brake pads are almost dead. the sensor is hitting the backing plate and sending a signal to the ecu that the ebrake is being used. it's REALLY not, but it's just a warning that the pads are due to be changed.
  4. Kokopelli
    low brake fluid
  5. WJM
    low brake fluid.
    Check pads. They are likely LOW LOW LOW and in need of replacement.
  6. jayjaysti
    jayjaysti Member
    thanx guys
  7. FACE
    let us know!
  8. Alex
    Didnt think about the rear pads being low, good call.
  9. dontcallitarex
    dontcallitarex Active Member
    Yeah, definitely the rear pads. I let mine go for way too long on my 04 Forester and the same thing happened. Get them replaced before you have to replace your rotors, yo.
  10. UpSideDownDesi
    UpSideDownDesi Active Member
    no more brake boosting for you lol
