easy turbo upgrade?
Discussion in 'Modifications & DIY how-to' started by bjtyson3, Jul 27, 2008.
  1. bjtyson3
    bjtyson3 Member
    what is the easiest turbo to swap onto an 05 sti? are there any that mount to stock up/dp and dont require tgv deletes to run?
  2. nsvwrx
    nsvwrx Active Member
    20g...
  3. pEd
    Any stock mount turbo, with a 2.4 inch inlet will fit.
    These incluse 18g, 20g, green/sz49/gt49, red/sz55/gt52, the blouche dominator series.
  4. bjtyson3
    bjtyson3 Member
    i know that the red requires tgv delete to use..are there any that dont?
  5. BKiller
    BKiller Active Member
    And don't forget to sell me your stock turbo for cheap!
  6. pEd
    ^^ Yes, sorry the red is only a 3" inlet.
    Any of the others I listed will work fine.
    You HAVE to make sure it's a 2.4" inlet, then there will be no TGV problems.
  7. bjtyson3
    bjtyson3 Member
    ok..one more ???..do all of those turbo's require any other mods??(walbro 255,injectors?)..i have a stage 2 sti but have a perrin 2.4" inlet and i already have a walbro fuel pump...anything else needed,i would really like a turbo that doesnt require many more parts because i am on a tight budget
  8. integroid
    I would say almost all of them would require at least a fuel pump and tune at the very least. I would get the above mentioned plus bigger injetors if going with 20G or bigger.
  9. bjtyson3
    bjtyson3 Member
    tune and injectors no problem..i will look into a 20g i think
