Ebay Clutch question
Discussion in 'Modifications & DIY how-to' started by ChrisW, Oct 20, 2011.
  1. ChrisW
    ChrisW Member
  2. Cool_____
    just get oem
  3. b reel
    pretty much is an OEM, the question is the spring force on that pressure plate?
  4. Cool_____
    That's why I said get OEM. Too light force it'll be crap. Too much bye bye tranny.
  5. ChrisW
    ChrisW Member
    So oem pp and flywheel and beefed up clutch?
  6. Cool_____
    Will oem clutch not hold 180 tq?
  7. ChrisW
    ChrisW Member
    Well, id like to give myself a little room to play down the road. maybe a vf39/tbe/stage 2 flash, nothing too serious.
  8. Trancetto
    Im pushing 280hp 280 trq on OEM stuff.
  9. ChrisW
    ChrisW Member
    On OEM rs stuff?
  10. Cool_____
    I'm not 100% but I think the OEM RS stuff is pretty much the same as WRX stuff. Can't you just get an OEM WRX setup? Matt should know this one.
  11. Jake
    thats the case when there were WRX's and RS, so GD chassis only. I bought an exedy stage 1 clutch off ebay a few years back, it was more than sufficient to hold 300hp my old WRX currently has. and has close to 125k on it now
  12. liltoua
    liltoua Member
    WRX clutch stuff won't work on the RS transmission.You need to get a clutch and flywheel that is specific to your transmission. Don't quote me on this, but I think the 02-05 WRX are a pull type transmission and the RS I know for a fact is a push type. You might be able to get away with running an 06+ WRX clutch, but I've had no experience with that.
    The stock RS clutch also won't hold the power if you are swapped on a OEM replacement clutch. It will hold, but will probably start slipping once on boost. Most swapped RS guys run the ACTSB2-HDSS clutch. That clutch will be good to hold the power you need and if you plan on upgrading as well.
  13. ChrisW
    ChrisW Member
    Awesome, thanks for the info.
    I may need to host a get together at my house sometime in november to tie up the loose ends of this swap and get it cranked for the 1st time.
  14. liltoua
    liltoua Member
    HAHA, I'm in the same boat as you. I'm finishing up connecting everything and finding out if I did the wiring right LOL. Good luck!
  15. ChrisW
    ChrisW Member
    Lol nice, I just did a full interior swap to avoid having to merge a million things. I've yet to test things, though. Where at in gwinnett are you, maybe can help each other out.
  16. liltoua
    liltoua Member
    I'm in Lilburn. yea I was thinking about doing a dash swap, but my funds ran out. You wouldn't happen to have a 2 pin alternator laying around would you?
  17. Sparta
    Get Oem. I had an eBay 6 puck and it lasted me 15k miles
  18. Matt
    yes...as Toua stated, the RS transmission uses a different type clutch over the WRX. IIRC, even the 06+ wrx clutch is still pull versus push.
    You will need the n/a impreza clutch setup for it to work.
