I know this is a long shot, but does anyone have any ECU pins for either a WRX or a honda Civic (They are all the same pins). I'm trying to run water injection of the factory ecu via ecutek and the pin isn't pinned out for a WRX. Thanks!!! -Michael
You will need the documentation from EcuTeK directly. There are several pins that are used as voltage triggers that can be used for water injection, but the technical details on that are a bit vague. I understand there's a modification you need to make, but whether that's a mod to the connector to add a wire, or whether you actually have to add a contact on the ECU side I have no idea, as I've never tried it myself. The forums on www.ecutek.com are the best place to start. David Power and/or one of the other folks from EcuTeK UK should be able to help you on there.
D'oh! I'm an idiot! You need the actual pin itself. I know a guy who can get them for you... David Carter, he is a member on subaru-svx.net, and goes by member name "svxdc". He lives here in Atlanta and makes a lot of wiring harnesses for stereo stuff, etc for Subarus. I think his NASIOC username is also svxdc, try emailing him through the site there.
Just for future refrence Porter, the pin you use is Intercooler Water spray. It isn't pinned for WRX. It is 12v off and 0v on. Thanks for the info Porter!!! -Michael
