EGT cel
Discussion in 'Modifications & DIY how-to' started by emstraumajunke, May 8, 2007.
  1. I know its been covered and i know its a 2.2K ohm 1/2 watt resistor, but what I dont know is do you un plug the egt sensor and fit the resistor in the plug or cut the wire and put it there. main reason for this question is I just put the Sti up pipe on my car and there no egt sensor in the uppipe not even a hole for it and of course im getting the cel for it and i want to fix it just not sure how to go about it. I know somewhere on NASIOC there a write up but digging in the 90000000000 post takes a ton of time and Id reather post on here instead of there and ask I wont get hung here. Thanks for the help.
    for the one that are going to ask I took the Helix flex up off cause i thought the flang welds were crack causing a leak but it was in the header and Im to lazy to go back and put the helix back on.
  2. moose
    Unplug it, cut the legs of the resistor down a bit, and just jam the resistor into the plug, then cover with some electric tape.
