egt sensor install - cut a bolt
Discussion in 'Modifications & DIY how-to' started by gte123v, Jul 26, 2006.
  1. gte123v
    gte123v Member
    Apr 23, 2006
    310
    0
    well guys, i tried to install my egt sensor tonight, needless to say, it didn't get very far. one of the bolts that connects the headers on the driver side and the crossover pipe was IMPOSSIBLE (I used my whole body, yes including my legs) to unscrew. So i had to resort to the tremel and cut the nut off :eek:hnoes: , so now I need a new nut and bolt. Does anyone know the part #?
  2. nsvwrx
    nsvwrx Active Member
    Oct 8, 2005
    2,726
    0
    why are you installing it//?
  3. gte123v
    gte123v Member
    Apr 23, 2006
    310
    0
    I already have the gauge in, i just got around to installing the actual sensor tonight.
  4. nsvwrx
    Oct 8, 2005
    2,726
    0
    Ah, let me look and see if i can find it
  5. gte123v
    gte123v Member
    Apr 23, 2006
    310
    0
    thanks man!
  6. goixiz
    goixiz Active Member
    Oct 23, 2005
    1,482
    0
    what bolt size and length ?
    I have a bucket of bolt/nut from my 1/2 cut that i stripped till my arm was sore
  7. gte123v
    gte123v Member
    Apr 23, 2006
    310
    0
    it's a 14mm nut/bolt that's is 3.7cm long
  8. goixiz
    Oct 23, 2005
    1,482
    0
    14mm ??? is that the wrench size or the thread size
    thats a huge bolt dont think it can strip that easily. normally bolt sizes are thread size
    is it a bolt or a stud ?
  9. gte123v
    gte123v Member
    Apr 23, 2006
    310
    0
    sorry, it's the wrench size, not too sure what the thread size is, but it is pretty big. not too sure what happened, but it just siezed up, so dremel to the rescue.
  10. goixiz
    Oct 23, 2005
    1,482
    0
    probably M10x1.5 40mm long
    14mm wrench ? hmmmm thats an odd size though
    #10 goixiz, Jul 26, 2006
