EJ 205 rebuild Kit?????
Discussion in 'Modifications & DIY how-to' started by WRXCoupe, Dec 15, 2008.
  1. WRXCoupe
    WRXCoupe Active Member
    I noticed a few reasonably priced engine rebuild kits with forged internals for the ej205. I am not in the market for a hybred, or an ej207 simply due to the limited funding I have available for car stuff, especially since a tranny will come prior to an engine. I thought it might be fun over time to bullet proof a used ej205short block, since they are readily available/affordable/sometimes even free. I will do this as a project and eventually swap this is in to and replace the existing bottom. My goal is a 350-400 whp high reving ej205/quick spooling turbo/ mated with a non dccd 6sp.
  2. nicad
    you can find used V7 shortblocks occasionally for about as much as you would spend on forged internals for the 205. food for thought
  3. siegelracing
    You can't spin a 205 any higher than a 257...
    One of the main advantages of the 257 is the "semi-closed" deck block. It's true that the pistons are the first weak point of the 205, so putting in forged pistons helps that, but the open-deck block is probably not far behind.
    Any turbo that makes 400whp is not going to be quick-spooling on a 2.0 liter.
    I hate to be down on your ideas, but there's a reason the ej205's are so cheap...
    Siegel
  4. WRXCoupe
    Absolutely great advice, no such thing as being down on the idea, basically helping and novice not to fail! I am really curious about the V7 shortblock as well. Is this the ej207 version 7 with AVCS? Can stock ej205 heads with the V7 shortblock?
  5. nicad
    yes, but you will only get the AVCS with the associated heads. said heads will run you $2,000.
    you should be fine with 205 heads with a 207 shortblock, but I haven't looked at the combustion chamber and deck heights in a LONG time, and the quench area might be an issue. they will physically bolt up fine, however. perusing nasioc may yield an answer, or just call up a reputable engine builder and they should know off the top of their head
  6. WJM
    You should find a blown EJ257/EJ255 and work with that.
    I have one. $300 takes it.
  7. Cool_____
    You will spend more money building a EJ205 than you would making a strong EJ257.
    Displacement is the replacement for power ;)
  8. WJM
    ^Truth.
    Now buy my block.
