Engine Noises
Discussion in 'Modifications & DIY how-to' started by Trancetto, Oct 20, 2008.
  1. Trancetto
    In the morning, and when leaving work (my engine cold) when i start the engine my car makes this weird annoying squalling noise for about 5-10 seconds tops, than it stops.
  2. WRXCoupe
    WRXCoupe Active Member
    Do you mean squealing, if it's squalling you may have a squirrel trapped under the hood, if it's squealing your belts might need changed!
  3. Matt
    yup, get the belts changed, STAT!
  4. Trancetto
    w.e. man :rofl: thx
  5. MrCoffeeATL
    MrCoffeeATL Member
    could also be the throw out bearing. My s2000 makes the same noise and that is the culprit. Depends on how many miles you have on the car nad when the last time your belts were changed. :)
  6. crashtke
    Just to add another thing to check, my AC idler pully made that same noise and ended up detonating into 100 pieces, breaking the belt and tearing into the timing cover slightly. I tried just to lubricate it...does not work. If that ends up being what it is, you can get a new one at NAPA for cheap....much cheaper than Subaru and looked almost identical. Mine went out under 100k miles.
  7. Sparta
    my A/c tensioner broke. Too much damn torque! But until I removed the belt off it was squealing
  8. WJM
    check AC/ALT/PS belts (2) and the AC idler pulley. 99.9% of the time this case is the ALT belt but the AC belt will need to be changed as well.
  9. WRXCoupe
    Take it to KingWRX
  10. WJM
    Yes.
  11. Trancetto
    KingWRX
    who is he, is that his name on here so i can pm him?
  12. Trancetto
    being bored at work today, i could not stop thinking about that part of the comment. I had a big smile on my face all day! :rofl:
  13. Sparta
    kingwrex
  14. Trancetto
    kingwrex
    ok thx.
  15. wagunz_pwn
    JDM Possum...again?
  16. kingwrex
    kingwrex Supporting Member
    bring it by subaru of kennesaw and ill be glad to check it out for you. im out of town this friday through sunday.
