Exhaust Cutouts?
Discussion in 'Modifications & DIY how-to' started by xerxesXXVII, Feb 4, 2009.
  1. xerxesXXVII
    xerxesXXVII Member
    I want my car to be a sleeper, plus this is the dd/roadtrip car for my wife and I. I was thinking about leaving the stock exhaust on, and just having an upgraded dp to electronic cutout in the forward section. Does anyone have any input about this? Yes, I do know that it is going to be loud as hell, and I am contemplating a solution for this. What do ya'll think?
  2. Mike@TTR
    Mike@TTR Active Member
    Get a good quality quiet turbo back instead :) If you just really like the noise, go for it. But you would need a tune to take advantage of it. Me personally, I would prefer to always have the power rather than having to stop and switch the map every time I wanted to open the cutout.
  3. xerxesXXVII
    xerxesXXVII Member
    Thanks for the advice, I was wondering about whether or not switching maps would be necessary or not. Good info!
    Any suggestions on a good quality, quiet turbo back system?
  4. Mike@TTR
    There are quite a few out there. I am pretty fond of my TurboXS system. It is the one that necks down from 4 inch to 3 inch to 2.5 inch. It is not bad at all.
  5. wagunz_pwn
    Borla Hush = FTW!
  6. Davidwrx
    Davidwrx Member
    If I had the $, I would go Borla Hush. I went the cheap route and have sti catback. The problem is that the id of the STI is 2.38". However, since the DP necked to that diameter anyway (I have stromung, but Cobb is the same) I was not too worried about it. It is definately louder than stock, the wife does not complain too much - esp in the car. It is more noticeable outside of the car.
  7. blindfold
    blindfold Active Member
    all electronic cutouts will leak
  8. undrgrndrdr15
    undrgrndrdr15 Active Member
    i have a prodrive axleback if money is a thing and you dont want a full system
  9. Brian
    Brian Active Member
    cutouts are more fun :p and with a stock exhaust there's no "cat back drone"
  10. Mike@TTR
    I have no drone in my cat back...and I run a test pipe ;) Oh and the LGT has no drone with the SPT cat back...it is almost too quiet at cruise. It is made by bosal.
  11. siegelracing
    There are some higher quality cut-outs. As long as you put the cut-out in the right place it doesn't effect the tune much at all. It is a riot to go from really quiet to straight-pipe loud with the flip of a switch ;)
    Siegel
  12. xerxesXXVII
    xerxesXXVII Member
    That is the exact reason I was considering it. Thanks Scott!:bigthumb:
  13. dontcallitarex
    dontcallitarex Active Member
    I've got a pretty loud turboback and it doesn't drone that much on the highway at all. I would much more highly reccommend you pick up a quality, quiet turboback. The Cobb, for example, sounds wonderful, is surprisingly quiet, and it very high quality. Also it doesn't ave the melon shooter can on the end. Perfect sleeper exhaust. With the cutout you would have to change maps every time you open the cutout to prevent overboosting. Unless you drive a bugeye. :)
  14. Cool_____
    I have a cut out....sort. Greddy Evo2 Catback = quiet car. EWG with atmospheric dump = BUSINESS at WOT!
    :keke:
  15. Mike@TTR
    Think you hit the nail on the head CoolRex. Best of both worlds.
  16. WRXCoupe
    WRXCoupe Active Member
    Just go with a HKS and see if your wife truly loves you! It comes with a plug if you want it quiet that actually works, I call it the girlfriend mod!
  17. Cool_____
    But plugging the exhaust isn't recommended. Makes more backpressure. I plugged my Blitz on the honeymoon and the car drove fine but the ECU was complaining and yanking/adding fuel constantly. Took plug out and ran smooth as butter.
