Exhaust Leak Question...please Help
Discussion in 'Modifications & DIY how-to' started by Goose013, Sep 26, 2005.
  1. Goose013
    Goose013 Member
    Hey, I installed my ScoobySport downpipe and cat delete pipe over the weekend and need to know what to do about the donut flange at the intermediate pipe. Will I be able to use a standard exhaust gasket like the one at the axel back or will I need to replace that whole pipe since its not a donut gasket? As it stands my car sounds like an old VW bug when I take off...lol.
    -Russ
  2. Goose013
    Goose013 Member
    by the way Chris, you were right...the next mod will be the Cusco heat shield!
  3. Alex
    I would recommend using a flat gasket and flipping the donut gasket around as well. This will give you the best seal, otherwise you're going to be semi stuck with a small leak. I never flipped mine, the leak is barely noticable.
  4. Weapon
    ^^^yup^^^
  5. Goose013
    Goose013 Member
    thanks, sounds good, also a guy on nasioc told me he used 2 gaskets and it worked. Now to just find the gaskets. Classic was out and he said everytime they get them they sell out quickly.
  6. Goose013
    Goose013 Member
    by the way, will the donut gasket come off the stock pipe. I didn't try.
  7. Weapon
    it should but i wouldnt reuse it
  8. Goose013
    Goose013 Member
    hell, it would be better than what I've got on there now...lol. I'll try tonight and then order up a new one. found a place I can get one for $26.
