So I was sitting in traffic today on the way to school, let off the brake and hit the gas to go when i hear that the engine sounds different. deeper, and a constant whooshing at all RPM's, but worse when the turbo is engaged. I'm hoping it's only an exhaust leak, and it sounds like it's coming from either the turbo/DP joint or the joint from my Short DP to the midpipe with the third cat. Gonna try some powder after school and see if i can find it for sure. :evil: ~Craig's parents wonn't be pleased when they find out his car is messing up because of something he installed
Powder's a pretty good idea for it. Are you saying you have a leak because you hear it or you can smell it?
You should have heard my parents when they found out I blew my tranny. Hopefully its just a minor leak, maybe you can just double up on the gaskets.
Good luck fixing your problem, hopefully it is only a leak and all you will need is new gaskets or to double up on them.
im not a big fan of the shorty downpipes just because its another place you can get a leak..however you can tell if its a dp leak by placing your fingers around the outside of the dp/turbo area and see if u feel any air coming out in between the 2..i dont know about doubling up on gaskets but subie dude makes some really thick gaskets you might want to check out..good luck partner
If you have an up pipe make sure the sensor didn't back out. Mine did a coupe times until I put some thread sealant on it. Hopefully that is it.
I took it after school for Scott Siegel to look at really quick, and his first guess was the same as mine that it was most likely the turbo to downpipe gasket, but I didn't have the money right then to get it properly diagnosed. However I did go ahead and pick up the gasket for that joint, does anybody think they could help me saturday morning take a look at it? I'm not exactly sure how to make sure that it's just a broken gasket. Craig
craig: that is disapointing to me that it is leaking. It held together for quite a while. Mine still hasn't leaked in 15k. Did you ever put in the mechnical cel fix? Stock gaskets don't usually just decide to fail. If there is a leak, it is know from day one. hummmm
I got in the mechanical CEL fix at the dyno day, *thank you porter*. I went ahead and bought the turbo-downpipe gasket at SoG, and I think me and a friend on saturday are going to attempt to replace it at his house (he needs to change his transmission fluid in his truck, which he screwed up a few nights ago during Jr/Sr. Wars. I'll let you guys know if I think we will need any help, but I think what I'll do is just double up the OEM gasket I bought with some of that silicone gasket gel stuff you can buy. Should that work? Craig
I still don't see how it could just leak. A double gasket could leak worse honestly. You can you high temp gasket maker to help make a better seal.
hmm, I'm not sure. I was sitting at a red light, and went to hit the gas when all of a sudden I noticed the noise was different. Scott siegel says it's probably a gasket also (and prob. the Turbo-DP gasket). I'm going to go out there right now and check and see if i can find where its coming from. Craig
ok well when I was out there right now, it is smelling real rich which makes me think that it is before the cat in the midpipe. The other thing I'm noticing is that it's coming from the turbo area, so I'm not exactly sure if it is the turbo-DP joint. Porter said it was most likely post-turbo because it doesn't change pitch when the turbo engages, it is always bad lol. Anybody have ideas of how I can check. To do the whole powder thing I would have to take of the heat shield. I don't have my stock uppipe, so I doubt anything has gotten knocked into the turbo, but it sounds bad so I can't rule that out Craig Also, I've lost a whole bunch of power from this leak. Hope this info helps nebody to diagnose it.
no it's a lot worse than that, the car feels downright boggy. Craig p.s. My car is only hitting .77 bar max, which is worse than what I was hitting last summer without any mods, and my BOV is barely getting any air, it seems to barely let the air escape. Craig
if its a leak before the turbo is will sound like a high pitch squeal..if its after the turbo its more of a whooshing sound..not sure why you are losing boost..have you checked all your I/C hoses..even with a huge uppipe leak i was still hitting 1 bar of boost..?
suppose it could be an IC hose. I can't exactly pinpoint where the leak is coming from, but it's from the turbo area. Thought it could be one of the hoses around that, but didn't think that would make me hear the engine a lot louder under the hood when it's idling. Not a whooshing noise or a high pitch whine. Craig
fixed. the temp. sensor had come out of the bung in my Helix flex uppipe, patrick (gotsol) helped me get it back in there. Thanks Patrick, thats twice you've saved me! Craig
