Firing order?
Discussion in 'Modifications & DIY how-to' started by FrankenSTI, Jan 9, 2006.
  1. FrankenSTI
    FrankenSTI Member
    Firing order? NEED HELP BAD.
    I have a mis fire on piston number 4, I have replaced my plugs already and that isnt the problem it may be the coil pack, i need to know which one is number 4, and how to tell if it is the coil pack. :bowdown:
  2. rolling_trip
    rolling_trip Active Member
    you could switch coil pack with #2, and see if the problem follows the coil pack. i had that a while back and it turned out to be my injector, so dont rule that out
    firing order is 1-3-2-4
  3. FrankenSTI
    FrankenSTI Member
    I have one more question. What are some symptoms of a borke motor mount possibly driver side?
  4. Alex
    I would expect to see a substantial amount of play and increased vibration if a motor mount was broken.
  5. FrankenSTI
    FrankenSTI Member
    Well i have a popping noise in my front right figured it would be a cv joint but it feels solid.
