First Power Mod
Discussion in 'Modifications & DIY how-to' started by cannarella, Dec 6, 2006.
  1. cannarella
    cannarella Member
    I still have my 100 SOG bucks from the scavenger hunt burning a hole in my pocket. I assume that equals $100 at SOG. I want to start doing some small power gain mods. I can’t afford to shell out for a Access Port or Ecutek yet but wonder what I could get from them you start getting some small power gains. I was looking on the SPT site and saw the SPT High Flow Intake. Any thoughts good or bad? I am willing to shell out about $150 on top of the bucks. My next mod would probably be a new DP and gut the UP. So please let me know if I need to look at anything else or if you have any other suggestions.
    Thanks
    Andy
  2. SonicBoom
    SonicBoom Active Member
    I'd skip the intake and hold the bucks till you need a pro-tune down the road.. I don't care for the SPT line. Unfortunately, there are no cheap mods for our car......
  3. moose
    Wanna bet? While the list pricing on new stuff is pretty high, you can do a LOT for a little if you're willing to learn. :) How about 280+ whp for < $1k?
  4. Strayen
    Strayen Active Member
    moose, give me the lowdown, I'm willing and able to do that. :)
  5. moose
  6. cannarella
    cannarella Member
    I am open for suggestions... What is the formula? What can I do now? Should I just go ahead and do the UP and DP now?
  7. moose
    I would do engine management before UP/DP on an 04/05.
  8. cannarella
    cannarella Member
  9. moose
    Sorry, I should've written a bit more.. the reason being the closed loop to open loop delay which is a bad thing on a stock car and just made worse with mods. It's an absolute abomination and Subaru should be ashamed of it, and it should be the first thing anybody addresses before making power mods.
  10. cannarella
    cannarella Member
    Huh? Are you talking about engine management?
  11. moose
    Yes, engine management is the way to deal with it; it's just a set of parameters in an ECU table.
  12. cannarella
    cannarella Member
    And that can only be done via Access Port or Ecutek correct?
  13. moose
    Yep, or OpenECU for a fraction of the cost ;)
  14. goixiz
    goixiz Active Member
    Tactrix cable (<$100)
    ECU flash Free
    STg1 ROM Free
    SOG bucks - Diff and tranny oil change, oil filters, alignment, etc,....
  15. cannarella
    cannarella Member
    Hey there Ming. What is your opinion? Is what you listed for OpenECU?
  16. goixiz
    Moose and I are on similar tracks - OPENEcu yes
    he has more knowledge and im just tagging along andd learning and have some fun
  17. cannarella
    cannarella Member
    I am now interested...
  18. cannarella
    cannarella Member
    So is this safe? Is anyone here using it? I assume that with it you can't go and get a tune from SS or anyone else?
  19. goixiz
    Safe ? only you can answer that Q.
    You are in full control of it. I would not enter a digit if i dont know what will happen if i do so.
    SS can tune with OpenEcu As well, just make sure your AC is working
  20. cannarella
    cannarella Member
    OK, now it is looking real promising. Is that what you are going with?
  21. crashtke
    Or gut your cats, go OpenEcu and flash stage 2 right? I went a different route and I am not disappointed in any way. I already had an accesport as well as a TBE on my car when I bought it. I paid an additional $400 and got Street Tuner as well as a LC-1Wideband O2 sensor for my car. Self tuning is fun, but read a lot first or ya can screw things up.
  22. cannarella
    cannarella Member
    Yea, I will leave the tuning to the professionals. I may look to get a gutted UP and purchas a DP and wait for an install day for help installing. Then take it to SS for the final touch. I am definitally not just going to jump into this.
    Andy
  23. Strayen
    Will I need a gutted UP on a 06 WRX? Someone said it's the same as in a 06 STi, SS informed me that the UP on the car is totally fine to work with other DP and exhaust. How hard is it to have MAPs with openECU? Do I need to have my own laptop to do this (I have my old one from college which is very tempermental). The possibilities are looking good with openECU, which frees up $600 to put in safety or or bolster the upgrade.
    Can someone link a post or website comparing openECU to AP? Pros and Cons? Thanks
  24. moose
    Yes, the 06 doesn't have a cat in the UP.
    You need a laptop to flash changes to the ECU.
    As for pros and cons, you really need to read up and judge for yourself. Each person has different priorities as to what is important and what is not. There's an OpenECU sticky thread in the power/engine/something forum here that I put together a few months ago that would be a good start.
    By the way, they are doing testing on the real time tuning with Enginuity now. Not up to speed on the details, but apparently they had a massive breakthrough in that area.
  25. Alex
    I'd definitely say a gutted UP & a sti axelback are the way to go for a cheap increase on the butt dyno.
  26. BelvnAWD
    But if he is going to buy a gutted UP, he may just want to look around for an used aftermarket UP as they can often be had for similar prices...
  27. goixiz
    if your laptop or cable is questionable - dont try it
    And if your car battery is weak dont do it either
    one slip there and you may need a new ECU
  28. cannarella
    cannarella Member
    So Alex, you are more worried about the UP? Which I am also. What about the restrictive DP? With that restriction I would that that a STI axle back would not help much.
  29. Alex
    Good suggestion :)
  30. cannarella
    cannarella Member
    What are the pros and cons of gutting the stock and getting and aftermarket UP?
  31. Alex
    Gutting is free if you DIY, or there is a vendor on here (10th St JDM) who will sell you one for $80. Advantages? Its your stock pipe with the cat removed. You are guaranteed 100% OEM fitment (because it is OEM).
  32. crashtke
    Just make sure you get all the nastiness out of there. You really have to make sure it is ALL gone. No real cons except better spool and more power. Cheaper than a TBE aftermarket, but does not yeild quite the same gains. Alex beat me to it....damn you lightning fingers!
  33. cannarella
    cannarella Member
    I will just have to cross that bridge when I come to it... I am going to focus on the OpenECU for now. That has me really intregued.
    Thanks
    Andy
  34. cannarella
    cannarella Member
    Tactrix cable is on the way thanks to birthday money. :) At least I can download my ROM and check it out.
    Moose can you elaborate more on the whole open closed loop thing that you were talking about? I am not going to make any mods without having someone present that has more knowledge then me and we can talk about the changes.
    Anyone with experience in OpenECU going to be at the next insatll day?
  35. moose
    Well, briefly:
    The stock O2 sensor is a narrowband sensor and is only accurate within a very small range. Ergo, it can only work reliably for anything near 'cruise A/F ratio' which is normally 14.7:1. This is 'closed loop' where the car keeps checking the O2 readings to ensure that it's fueling appropriately. It will make any necessary corrections in the short and long term fuel trim tables.
    14.7:1 is entirely too lean to run on a turbo car under boost. You want to run closer to 11:1 or in that general neighborhood. Since the stock O2 sensor can't provide any accuracy in that range, the ECU is essentially 'flying blind' and fueling the car based on calculated values (injector size, MAF scaling etc, as well as the fuel trim tables mentioned above). This is 'open loop'; open meaning no feedback from the O2 sensor is taken into consideration.
    The issue with the 04/05 WRXs is that due to some EPA regulations (at least that's the most common story), a mandatory 'enrichment delay' was put into the ECU. This forces the ECU to wait a certain amount of time (2-3 seconds) after open loop is triggered before it actually moves from closed to open loop fueling. During this time your engine starts making lots of boost and RPMs, and the end result is that open loop and richer fueling doesn't kick in until well AFTER it is triggered/needed. Basically, you'll be running very lean under boost, which is not good. The 'stumble' you can feel is when the ECU finally is allowed to enter open loop and radically enriches the fueling.
    Hope that makes sense.
  36. cannarella
    cannarella Member
    Ok, I got the cable today. Now I have not found any instructions on how to download my basemap off my car. What do I do?
    Moose, any recomendations? I would like to get this open closed look thing fixed also. What table is it in? Are you going to be at the next install day?
    Sorry I have so many questions. Just getting excited and want to do it right.
    Andy
  37. Alex
    Alex > you :eek:
  38. cannarella
    cannarella Member
    Ok I flashed with the stage 1 map from osecuroms. I am feeling some more peppyness in her. I have not put a full tank through it but I think my mileage is better. I got some loot from Christmas, which I hope everyone had a good one as well, and am ready to purchase a DP. I have a line on a stock UP that is gutted and ready to go. So as soon as I get a DP ordered, I will be ready to install and flash stage 2. I am happy with the OpenECU so far.
    So any recomentations on DP? I have heard good reviews on price and performance on the Stromung ceramic coated DP from GOIXIZ. Any other votes? I am looking to keeping the rest of the exhaust stock for now...
    Andy
  39. moose
    I love the Helix catted one, and it has a bung for wideband sensor which is a nice bonus.
    I would recommend doing the uppipe as well, since you don't want to give the cat that's in there more incentive to poop itself into the turbo...
  40. crashtke
    ^^Agreed on the UP. As for DP I have a turbo-xs 4"-3" bellmouth that I like quite a bit. You can actually hear the turbo a bit.
