First time at the drag strip
Discussion in 'Meetups & Events' started by flip, Jul 24, 2006.
  1. flip
    flip Member
    Feb 2, 2006
    658
    0
    So this weekend was my first time at the drag strip. It was so much fun!! I think I did pretty well considering. I ran my car 3 times and here are my results. What do you guys think?
    Run 1:
    My first and best. Pretty good launch, maybe a tad too much wheel spin.
    R/T 1.205
    60' 1.839
    1/4 13.653
    MPH 98.82
    Run 2:
    Bogged launch a little. Missed 5th. Didn't grind, just wouldn't go in. I really need new tranny fluid...
    R/T 1.170
    60' 2.042
    1/4 13.825
    MPH 96.81
    Run 3:
    Bogged launch a little again. Shifted slower so I wouldn't miss gears until I replace tranny fluid...
    R/T .929
    60' 2.027
    1/4 13.994
    MPH 97.99
    The only engine mods I have are a downpipe and exhaust...
    Tips? Hints? Advice? What do I need to work on to get my times lower?
  2. suby113
    suby113 Member
    Apr 10, 2006
    602
    0
    Pretty much it would be your launching and gear shifting that will get you your lower times. Just my 2 cents!
  3. yerrow
    yerrow Active Member
    Jun 23, 2004
    1,340
    0
    keep those 60 foots under 2
  4. miloman
    Feb 3, 2004
    12,774
    1
    thats pretty good considering its your first time...
    my first time, i stalled out :rofl:
  5. flip
    flip Member
    Feb 2, 2006
    658
    0
    haha :)
    Once i fix this tranny issue my shifting will be quicker which should help out the times... My 1,2,3 shifts were quick but 4,5 were kinda laggy...
  6. heathbar
    heathbar Member
    Apr 17, 2006
    542
    0
    Pretty nice numbers. I'm suprised your first run was your best! Everytime I go to the track, my numbers always get slightly better with my first run being the worst.
  7. flip
    flip Member
    Feb 2, 2006
    658
    0
    Heh, i think it was the fact that the second and third runs i was wearing a helmet that i borrowed from someone and was wayyyy too small LOL. I actually hurt my neck smashing the helmet on the first time...
    After my first run the guy at the slip booth was like no helmet? i saw nope, do i need one? I've never dragged b4. Apparently at commerce when you run under a 13.99 you gotta wear one :p.
  8. MarkM2016GTI
    Supporting Member
    Mar 11, 2005
    2,549
    0
    Man, those are great first times!!!. Way to go...
    Mark
  9. jt money
    jt money 350hp mmm mmm Good!
    Supporting Member
    Apr 16, 2005
    4,107
    0
    yes at any track you have to wear a helmet when making times below 13.99. also remember your supposed to wear pants when driving not shorts. man these look like great times for your first time out. what i would work on is getting the 60' at 1.8 or lower consistantly. i dont know if your shifting at redline or not but if you are try shifting a lil lower like 6700 to 6500. these are little improvements you can make on already good times. keep up the good work.
    #9 jt money, Jul 24, 2006
  10. 1ll-WRX
    Jun 14, 2005
    2,819
    0
    I'm afraid of doing the same :eek:hnoes: ....
    Great times Flip!!!...gotta get to the track this season for sure
  11. mckenzietj
    mckenzietj Member
    Jul 8, 2005
    175
    2
    I agree, I've dragged my WRX several times and in the subie you can tear up faster cars just b/c of the launch advantage. BUT, careful on the tranny, slip the clutch and stay away from wheel hop, it's like beating your gears w/ a hammer. I've got the sheared trans gears to prove it!
  12. flip
    flip Member
    Feb 2, 2006
    658
    0
    I know about the helmet now... next time I'll have one :). I didn't know about the pants and had to trade my shorts with a friend that had pants LOL.
    As far as my shifting, i remember reading about the shift points in the sti being better slightly lower so i was shifting at right around where you said in every gear except for 1st which i ran almost all the way to redline. My shifts were slightly slow like i said since my fluid needs to be changed and i need to get it done before i try to shift any faster...
    I will work on gettin the 60's lower, just need to nail my launch better. I wana go out when i don't to wait in line so long to run. I want to be able to compare runs back to back while trying different things on my launches.
    Thanks for the input and advice!!!
  13. jt money
    Supporting Member
    Apr 16, 2005
    4,107
    0
    the only time youll get to go back to back is if you get there at opening on friday night. then youll get a few back to back runs before you chill.
  14. flip
    flip Member
    Feb 2, 2006
    658
    0
    I don't mind chilling for a bit, but there were a good 15 cars in front of me if not more, 4 lanes wide with a 30+ minute wait... It didn't seem like they were very efficent later in the day.
  15. jt money
    Supporting Member
    Apr 16, 2005
    4,107
    0
    its always like that. some times later in the year youll luck out and eveyone will think its gonna rain and you go out on chance and luck out. noone ther but a hand full few a few hours anyway. then back to 1 run an hour if your lucky and someone doesnt break or crash. i love to race but hate the wait.
  16. Cool_____
    Sep 5, 2005
    7,338
    0
    You have a STi so when you launch that bad boy stick it through. Let the AWD system pull you out if you fishtail (Lord knows I do and I look like I am about to go into the wall sometimes...at least it feels that way). Also I know it's hard but try not to redline 1st. My WRX pulls a lot harder if I hit the shift at 6250 rpms because you only have a 1500 rpm drop when you wind out the gears. Shifting at redline 7000-7500 rpm your rpms drop to 5000-5500 rpms. That is well over your peak tq curve esp with the STi and VF39. Shifting at 6250ish will net your rpms hanging around 4700ish rpm and you are a lot closer to your peak powerband.
    It's perfect for me as my peak tq hits at 4500 rpm. Think of it this way. With SS tunes and even stock our cars taper. Well that taper starts shortly after the peak tq which is way the tq begins falling. Would you rather shift and end up past the peak tq and boost lets say 19 psi with a final taper of 17 psi or would ya want to shift a little early and hit 22 psi and taper to 20psi? I think I'll stay in high boost.
  17. miloman
    Feb 3, 2004
    12,774
    1
    i have only seen that happen at the GA DSM and GA3S events at silver dollar... i got like 18 runs in last time
