fitment for control arms
Discussion in 'Modifications & DIY how-to' started by RamblinWRX, Jan 27, 2007.
  1. RamblinWRX
    RamblinWRX Member
    Does anyone know about fitting STI aluminum front control arms onto the wrx. I bent one pretty bad hitting a curb. Subaruwrxparts.com and the dealership have them but they say 04+ WRX on some sites, 02+WRX/STI on some. Been cruising around NASIOC but no one has a straight answer. If the mounting points/sizes are the same, wouldn't it just widen your track and give more caster?
  2. GTscoob
    I think the STI ones require a different front sway bar so you might need that plus endlinks in addition to the new control arms. Like I said earlier on the phone, I'm not really sure about what fits between sedans, I've always been more concerned with what doesnt fit on the wagons.
  3. FTZ
    Have you tried contacting SS or WJM. If anyone would know on our site, I would think it would be them.
  4. WRX-WRC
    as far as i know they will fit with out modification but bobby may be right, you may need a new sway bar.
  5. calmnothing
    You can either A use different endlinks or B use washers on the bolts with the endlinks you have now
  6. RamblinWRX
    RamblinWRX Member
    ok, so by different endlinks, you mean ones that are meant to go on an 04 STI? and that will still hook up to my stock sway bar? Gonna call up SS tomorrow i guess, no one else at SoG knew yesterday when i called.
  7. Alex
    JT should know, send him a PM
  8. calmnothing
