FMIC Question
Discussion in 'Modifications & DIY how-to' started by wrxracer87, Feb 28, 2007.
  1. wrxracer87
    wrxracer87 Member
    Hello as most of you may know there are two fmic kits for sale in the Private For Sale forum here. One is a txs with an aem shortram and the other is injen with the injen cai. I have only heard great things about the txs kit and was wondering which would be a better buy. From the pictures the injen fm looks a little puny compared to the txs one and i was just wondering if there was a significant performance difference in either one.
    Thanks in advance
    Taylor
  2. Alex
    Not sure on the actual performance difference, but the Injen is smaller and obviously will be an easier fit / install. Its also coming off another bugeye so you know fitment is good.
  3. wrxracer87
    wrxracer87 Member
    smaller also meaning less efficient at cooling intake temp... Correct me if im wrong.
  4. Weapon
    the core is quite a bit smaller than the TXS one but it really depends on how much turbo you are going with. Plus with the smaller core, lag is less of an issue if you do decide to go with a bigger snail. I had a vf22 @ 19lbs tuned by SS with no problems/no knock what so ever and suffered minimal lag. Plus with the Injen you can use a Cold Air Intake vs a Hot Air Intake :) Either way a front mount is much better and more effiecient than the stock topmount.
  5. wrxracer87
    wrxracer87 Member
    I am planning on going with a deadbolt 20g in the near future. Hopefully i will be putting down around 330 to 340ish hp. Do you think the injen fm will be big enough for such an application?
  6. reconracer
    reconracer Member
    I would go with the TXS for there reputation, very few cars run injen products, since you you plan on going with a 20G I would get the TXS since its a good size, I personally run the Perrin FMIC with my 20G setup
  7. wrxracer87
    wrxracer87 Member
    What kind of numbers did you get out of your 20g and what other mods do you have??
  8. reconracer
    reconracer Member
    Im in Fairbanks, Alaska for another 24 hours, moving to Fort Stewart. There's no dyno or protuner here.
    mods for the blackhawk in my icon are classified but for the wrx they are
    perrin tbe,
    perrin fmic
    borla headers
    deadbolt 20GTD05
    PE 800 injectors
    samco turbo inlet
    utec
    brembo/rotora bbk
    ur uppipe with tial 38 ewg
    17x8.5 5zigen pro gn
    helix coilovers
    whiteline front/rear swaybars and endlinks
    energy suspension bushing kit
    white front and rear tower struts
    2 million dry n0s:eek:hnoes: just kidding
