I just did the mod from scoobymods.com for enabling the fog lights with only the parking lights on. Everything worked fine for a few days and now the fog lights no longer come on with the parking lights. Has anyone else done this mod and experienced a problem like this???
My freaking check engine light came on after i rechecked everything so i just rewired everything the way it was before.
ouch that sucks. i did the fog light on with high beams. it let me turn them on with parking lights also. never had a problem. i dont know how much these mods differ if at all. i had one short were the wire sliped out of the end of the tape and grounded and all that did was turn themm off. these are the instructions i went by. Begin by removing the dashboard underneath the steering wheel, which comes off with three screws. This exposes the fuse box and relays, which must be removd from their mounts to provide access to the wires in back. The fuse box is held in place with one screw, which is on the top, and several tabs.The relay box is held in place with tabs only. With the fuse box removed, splice a 6-10 inch piece of wire (18g) into the ORANGE wire coming from the parking light power supply on the back of the fuse block. Terminate this wire into the RED WIRE WITH A GREEN STRIPE coming from the fog light relay, which is the FOURTH relay down from the top. Tape off the RED AND GREEN WIRE and tuck it out of the way.It won't be used. (was the power supply for the fog lamp relay) Test before putting back together.
yeah thats the ones i used as well. i prolly should recheck fuses and make sure none of them are blown.
