Fog lights
Discussion in 'Modifications & DIY how-to' started by Deke, Jun 19, 2006.
  1. Deke
    Deke Active Member
    So a friend just brought it to my attention the other day that one of my fogs is out. The light isn't cracked or anything, so I guess the bulb just went out. Is it hard to change these? I haven't even really looked at it yet, just wondering. Also, and kind of bulbs that you would reccomend. I'm thinking about going yellow, but I'm not sure if that's a bulb or just the film you can put over it. I'm just curious what kind of bulbs you guys would reccomend for either white or yellow.
  2. jt money
    its very easy to replace the bulbs. its like 3 phillips screws around the light on th efront side. as far as the yellow most of the yellow fogs on here are yellow cause of the rockblocker film. i dont know the size or model of the bulb.
  3. wrxin8or
    Yeah, it is really easy to change the bulbs out. There are 4 screws around the foglight housing, but one is used only for aiming the beam. Take out the other 3 and it comes right out, and changing the bulbs is simple then.
    Also, the best way to get yellow fogs is to get the rockblocker, which I have and love. Then again, if you dont want your fogs to be yellow all the time you might not want this.
  4. Trey
    Trey Active Member
    I think the bulb is an H3 but you can pull yours and it will be stamped with the type.
  5. wrxin8or
    Yeah I think it is an H3, but its an H3 foglight bulb or something like that.
  6. Deke
    Deke Active Member
    thanks guys, I'll probably end up taking care of it today.
  7. 1ll-WRX
    keep us updated as where you found the bulb....kinda wondering if it's a normally stocked item at the usual auto parts stores....never looked personally
  8. wrxin8or
    They had it at the local NAPA by my house in Marietta
  9. Goose013
    Goose013 Member
    Autozone and napa both have them, its a common bulb
  10. Deke
    Deke Active Member
    yeah I found it no problem. I almost went for the a new set of silverstar H3 bulbs (to match the headlights). But I didn't have the heart to fork out 40 dollars for two silverstar bulbs when I could one regular sylvania bulb for 7 dollars. Maybe next time...
  11. WrxCrazy
    WrxCrazy Active Member
    the bulb is everywhere not a hard bulb to find like e3's of the rear taillight sig bulb anyway it's ez
  12. 1ll-WRX
    so did they have any colored ones?.....blue, yellow?
  13. WrxCrazy
    colored ones?
    u like colored ones huh?
    i didn't see any but i tryed gel cap once dont ever do that it burns the whole hosing.. and u will need a new hosing for ur fogges.. good thing it didn't burn my car
  14. 1ll-WRX
    maybe get my rice on, ya know.....:coolugh:
  15. wrxin8or
    get the yellow rockblocker scott...it looks great on the silver bugeyes
  16. Deke
    Deke Active Member
    Yeah I didn't find colored ones. They might make them in the sylvania "Cool Blue" but I didn't see any. I'm relly not a huge fan of the yellow when you don't have the lights on, or else I'd go for the rockblocker. Someone on here has blue rockblocker on there fogs and it looks pretty good though.
