Found a Motor On EBAY No sure If I should buy it
Discussion in 'Modifications & DIY how-to' started by HKSTuner, May 28, 2009.
  1. HKSTuner
    HKSTuner New Member
  2. GTscoob
    Those are the oldschool WRX and STI motors from Japan. They're pretty bulletproof but you wont pass emissions and will have difficulty tuning them.
    The big plus is that they're dirt cheap but with the abundance of crashed WRXs over here you're just as well off picking up a used EJ205 that will be just as reliable and powerful as an EJ20G/K.
  3. nicad
    depends on what he uses for an ECU. there's no reason he couldn't use his stock ECU, and swap over the appropriate sensors (cam and crank) and coilpacks to the new motor.
