FP Green 3inch inlet results
Discussion in 'TopSpeed' started by Tray@topspeed, Dec 2, 2005.
  1. Tray@topspeed
    Tray@topspeed Member
    2004 Subaru STi
    - FP Green 3 inch inlet
    - External wastegate
    - 3 inch TBE
    - Perrin FMIC
    - Perrin Big MAF
    - Perrin 3 in turbo inlet hose
    - Perrin Modified Injectors
    - Snow Performance kit (Water & Meth)
    - TGV delete with custom porting by Will at TopSpeed
    - RPS MAX Series Clutch - Street
    - Ecutek
  2. Genya
    Nice job guys that yours tray?
  3. Kokopelli
    Looks like Tray got his car tuned just in time to miss the season at the drag strip. :p
    BTW very nice numbers.
  4. sol drums
    sol drums Active Member
    very nice!
  5. Brian
    Brian Active Member
    Nice. 4th gear and stock block? Do you guys do your own TGV delete or do you work with the APS deletes?
  6. Tray@topspeed
    Very similar set up to mine. Its a customers car from TN. He made great power with 93 and water & meth mix. Mine is still on a race gas "Road Tune" so no dyno numbers yet. But would be similar minus meth & external wastegate.
    The Perrin 3 inch inlet comes with TGV deletes. And Will took out the butterfly plates and did some serious port work.
    Tray M
  7. miloman
    very impressive
