Front Mount
Discussion in 'Modifications & DIY how-to' started by josh booth, Nov 22, 2006.
  1. josh booth
    josh booth Active Member
    How much change would it be on my 03 wrx going from a sti top mount to a front mount?
  2. slowwrx
    What turbo
  3. clemsonscooby
    clemsonscooby Active Member
    About a 1000rpm's!:eek:hnoes:
  4. Alex
    exactly my question.
  5. Weapon
    oh not that much! depending on turbo anywhere from 200-500rpms
  6. josh booth
    Stock for now
  7. JJang12
    JJang12 Active Member
    i saw about 300rpm spool difference with 18g turbo. However, I feel more lag especially at 1st and 2nd gear. you will gain more HP thru bigger turbo than upgrading to fmic.
  8. SonicBoom
    SonicBoom Active Member
    Probably hurt you with stock turbo..... Damn it'll look cool though!
  9. blindfold
    blindfold Active Member
    i would not upgrade to a FMIC unless there are plans for bigger turbos in the near future
  10. slowwrx
    What are youre plans for the car, autocross, track, street car, etc...
    Matt
  11. ARNOLDWRX
    ARNOLDWRX Member
    AIR-TO-WATER INTERCOOLER!!!
    That is what i run and it is great, the turbo spools very fast & hard because the intake runner from the turbo to the throttle body is only 1 1/2 feet or so.
    Also the intake temps stay pretty consistant also. NO TURBO LAG!
  12. josh booth
    Street car.
  13. slowwrx
    Large top mount will be fine.
  14. gotsol
    gotsol Active Member
    I'm not try to diss, but if your favorite mod is 19" ICW wheels then I assume you want the bling of the front mount. Performance wise, don't do it. BUt if you want "street cred" then go for it.
  15. josh booth
    I just like being difrent so it's cool.
  16. Brian
    Brian Active Member
    You could line the entire intake (from filter to turbo to throttle to manifold) in peltier coolers. That would be extremely unique(you'd be the only 1) and every computer mod'er would be jealous. ;)
  17. clemsonscooby
    I've been fooled a couple of times thinking some Honda's or Celica's had a front mount intercooler on them, but it turned out to be a CAI intake that mounts in front of the radiator. I don't suggest this with the Suby, because it would be like sipping out of a 10ft. straw. Just get the mesh grill insert, it sort of looks like a front mount.
  18. josh booth
    I like the top mount i just asked a simple qustion what whould a front mount do for my car.
  19. miloman
    i wouldnt go with a front mount unless im upgrading turbos
  20. josh booth
    Thanks miloman
  21. Greg
    Greg Active Member
    Come on guys, lets not be like NASIOC
  22. moose
    We'd need about 10,000 people posting off topic all day long where every other post is "FTW" or "lol" or "WAPCE" first. :)
  23. 1ll-WRX
    off topic: inter-foolers rule!!!! :ddirty:
    on topic: I agree with Milo...bigger turbo would be the only thing that would lead me towards a front mount...otherwise it'd probably be too laggy
  24. yerrow
    yerrow Active Member
    to answer the question...not much
    -you may pick up a few horses on the road
    -you probably will lose alittle responsiveness since you're on the stock turbo
    -you will like the way it looks
    -you will have to re-learn the power characteristics of the car. a guy had mahdavi motorsports install the perrin fmic (way to big for a stock td04) on his wrx. he actually came back the same day saying that boost response was weird and had to have sam check to make sure no piping was loose. he said that boost was off and responsiveness was slower.
  25. Nitro
    Nitro Active Member
    yeah i actually stopped posting over there.......i didn't feel like going into E-Combat:hsnono:
  26. karr83
    karr83 New Member
    Yeah... That actually was me. It was a total learning experience. Once I got a Protune from Doug at Topspeed, I became a very happy camper with the FMIC upgrade. 268whp and 264 lbs/ft torque on pump gas with the stock turbo. Very smooth delivery and it never stops coming.
