Gaskets for UP install
Discussion in 'Modifications & DIY how-to' started by moose, May 5, 2005.
  1. moose
    Just want to make sure I'm ordering everything I need. Upper and lower uppipe gasket, manifold gasket.. anything else? (I have the DP stuff already.)
  2. longfury
    longfury Active Member
    Why would you need a manifold gasket?
  3. moose
    The instructions I've seen require you to remove the manifold on the passenger side. Better way?
  4. FTZ
    I don't think you need to worry about the manifold gasket with just an uppipe. Check with Scott at SoG. It is probably just a waste of a few dollars if you need to replace it. I don't believe it is a crush gasket so using the stock one shouldn't be a problem.
