Ok I have this TurboXS stealth back just sitting around and I want to get it installed. I also want to gut the UP at the same time since the exhaust will be off. So what gaskets to I need to get and does SOG usually have them in stock? I know the 2 for the UP and the one that goes on the bellmouth and the axle back. Am I missing anyhting? Thanks
http://www.fastwrx.com/3in2hoexga.html You will need 4 of those since your have four different pipes and attachments. http://www.fastwrx.com/tuga.html One of those. http://www.fastwrx.com/mapiga.html ...and one of those. As far as SOG carrying them. I would go out on a limb and say yes, since they are crucial exhaust pieces and probably get replaced quite frequently. Since its a 3" turbo back, they may not have the larger opening gaskets.
Yup, sorry, forgot to include that one. I would definitely call to see if they have the enlarged rear exhaust gaskets. http://www.fastwrx.com/uppiga.html There are local vendors that probably carry them like Sakari, but I just showed you that site out of convenience.
I have the donut gasket and one 3" DP to cat that came with the kit looks to be in good shape. I have all of this already except for the bototm 2 gaskets. http://www.jscspeed.com/part_pictures/txs_wrx_tbe_sbe_hwk.jpg So I am thinking I need: one of these for the UP http://www.fastwrx.com/uppiga.html one of these for the UP http://www.fastwrx.com/mapiga.html one of these for the turbo to DP http://www.fastwrx.com/tuga.html a 2.5" for the axle back.
