Gear Oil, Cocktails, etc?
Discussion in 'Modifications & DIY how-to' started by GTscoob, Oct 10, 2005.
  1. GTscoob
    Wondering what all everybody is using in their transmissions?
    I'm sure I just have the OEM stuff, and will probably keep it for another month or so while I'm still learning, but I've heard a lot of stuff about aftermarket oils. Right now I'm having no problems getting the car into any gear (1st is iffy from a roll though), so maybe I should just stick with the oil.
    Discuss.
  2. 5spdfrk
    5spdfrk Active Member
    On nasioc search under "Uncle Scotty"s name and search for "cocktail." Everyone has been really pleased with his and I will be trying it when I change my tranny fluid.
  3. GTscoob
    Yeah, I was reading that thread earlier and wanted to hear if anybody on here was using it.
  4. brettedmonds
    brettedmonds Member
    actually i just did that mix in my tranny. before i couldnt shift into 1st until a complete stopand i mean complete, you can ask smoothcriminal.i couldnt hardly even double clutch most of the time. its been in for about 1200 miles now from a couple trips. right after used it, it was like driving a whole new car. if i want to i can shift into first while just pushing the clutch in all the way up until about 30mph. its awesome and i give it a 10++. you just drain your tranny fluid and the mix i used was
    1 qt redline lightweight shockproof
    1 qt pennzoil syncromesh (or gm synchromesh)
    fill rest with castrol hypoid c 75w90 if you can find it or 80w90 if you cant
    castrol and pennzoil can be found at autozone and a performance shop should have some redline.
    brett
  5. CROSSeyed
    CROSSeyed Member
    So far the only local place I've found w/ the light shockproof is:
    Mustangs Unlimited - Lawrenceville, GA 30043 (770) 446-1965
    9.95/ qt + tax
    Summit has for 7.95, but they have an 8.95 handling charge becasue its a hazardous material. May be able to get a case and split it and save some $$. I'd take 2-3 qts. I jsut called Summit and its 104.35 for a case shipped (~$8.70/qt)
  6. monk
    is there a benefit to this cocktail over using just readline gear oil? i always get a little leary when mixing multiple fluids (or rather the additives in the fluids).
    i'm coming up on 30k, i don't have any 1st gear shift problems (though i rev match everything, guess that helps)... but i definetly want to go with synthetic in the tranny.
  7. CROSSeyed
    CROSSeyed Member
    If you do use straight redline, do not use the light weight shockproof, you should use Heavy I believe.
  8. monk
    right, the 75w90 gear oil. oh, btw in case anyone is interested, i'm thinking of trying one of these: http://www.redlineoil.com/team_gear.asp
    there's a wrx/sti pack down the page. the price seems reasonable.
  9. brettedmonds
    brettedmonds Member
    i dont know. i just tried it and it worked wonders. it shifts smooth as butter now. get on nasioc and pm unclescotty . he came up with it and can probably help you with any extra questions.
    brett
  10. CROSSeyed
    CROSSeyed Member
    I'm gonna try the cocktail.
  11. MrCoffeeATL
    MrCoffeeATL Member
    Would this help with the cold winters here in ohio (for school) to make shifting easier when the tranny is cold? The first few shifts are always interesting (read double clutch to downshift at all) and I woulnd't mind trying something new if it might help.
  12. Genya
    I have used synchomesh before, and it was ok, however now went back to OEM with the clutch change and its much better. I hear synchomesh will help in the WRX tranny, but not so much in the 6-speed.
  13. jonnyboy0150
    jonnyboy0150 Member
    Anyone had problems with this?? I have a bigtime grind problem into 1st unless under 5 or 10mph. I am very interested in this cocktail but id like to hear from more people using it. I have straight redline now and it blows!
  14. monk
    redline isn't working for ya? other than the 1st grind what else is it doing?
  15. jonnyboy0150
    jonnyboy0150 Member
    The first grind is the main problem, i just hate being paranoid about it everytime i have to slow down. If that cocktail can solve that problem it would be wonderful!!!
  16. miloman
    i think thats common on most WRXs... they dont like going into 1st when moving
  17. jonnyboy0150
    jonnyboy0150 Member
    Just did the cocktail fellas! Its a huge improvement! I can get it into gear anywhere under 20mph w/no problem at all. I recommend this to anyone who gets the grind into first gear!! :bigthumb:
  18. brettedmonds
    brettedmonds Member
    good news to hear. that was the same mine was doing before i used the cocktail but i couldnt get into first until a complete stop. i highly reccomend it also. brett
  19. KingofSiam
    KingofSiam Member
    I don't know if this is thread jacking or not, but does anyone have any recomendations for ATF?
    *looks down sheepishly*
  20. GTscoob
    I think I had Amsoil Synthetic ATF in mine. Anything synthetic works best in the autos since it keeps operating temps down.
