I spun the tires the other night and suddenly after that i couldn't get it into any gears...it locked up on me....kinda scary hnoes: ...has anyone had anything like this happen or know what might have caused it?....i think someone said that the bugeye wrx had tranny issues but not sure about the specifics.....any help would be much appreciated!!
dang scott, if its still locked your in trouble. if its unlocked i think you will be alright, if your still under warranty i would have it checked out though.
Its fine now?? Maybe the linkage was binding? Hopefully you werent on pavement when you were spinning tires anyway!
i wasn't spining the tires that crazy....i was on pavement with new tires but it was wet...and i guess it was an aggressive launch....so you think it's the linkage?...should i have it checked out?....is it something that a warranty would cover?
wish i had warranty 86k miles isnt covered. I would have that looked at though man because if you ever go to the track how are you gonna launch?
Which gear is it locked into? Same thing happened to my car. I had to pay 2500 at the stealership to get it fixed. Could simply be the linkage, could be that you broke a gear. Kind of hard to tell to be honest. But i hope its nothing.
I'll be there at 7:30 AM.....they're going to change the tranny fluid or whatever...atleast $100 in the hole already...i'm sure the tab with increase...i never leave there without atleast spending $300...gotta pay to play i guess
i need to go over there sometime myself. Im gonna do my timing belt in a month i think. Tranny fluid couldnt hurt to be changed. I have that royal purple and it grinds a lot. Im switching to redline. good luck today bro.
i called SOG and they said they could change my tranny fluid out for around $100 dollars, but not sure it was the fix and didn't have a car for me at the time so they really couldn't investigate further without me leaving it for a while...it's my daily driver and didn't want spend $100 just yet so i didn't have anything done with it....it drives and shifts fine now....i think i'm going to change out the tranny fluid soon regardless..
