Going to get tuned on April 12th @ Topspeed
Discussion in 'Meetups & Events' started by Cool_____, Mar 17, 2008.
  1. Cool_____
    4 of us are going to Topspeed on Saturday April 12th for a mass tuning session starting at 10AM. Swing by if you want. Shoot we ought to have some sort of G2g Friday night....lol
    We are leaving work at around 2:30PM (maybe earlier) Friday so that puts us in the area at 8PM-9PMish.
    It's gonna be a fun day.
    Here's some info....
    Tune #1 -- Jason Sarvis -- wrxsarvis
    2004 WRX
    Cobb AP V1, VF39, Upgraded TMIC, STi pink injectors, GM boost solenoid, 3" catless exhaust and upgraded uppipe, stock intake with K&N filter, Greddy RS BOV, upgraded turbo inlet
    Tune #2 -- Derek Western -- WolfSong
    2002 WRX
    Cobb AP V2, Uppipe, 3" MadDad whisper catback, Perrin catless Downpipe, stock intake with K&N filter, stock turbo, GM boost solenoid
    Tune #3 -- Delette Collins -- Coolrex
    2004 WRX
    Ecutek, Deadbolt td05h 18g, Perrin FMIC, Perrin EBCS, SMC Meth injection running 100% meth, 820 cc modded stock injectors, APS 50/50 BOV, UR EWG 44mm, 3" catless exhaust with Greddy Evo2 catback, Sti 6 speed , Perrin turbo inlet
    Tune #4 -- Daniel Spivey -- Not registered on WRXAtlanta
    2002 WRX
    Cobb AP V1, Blouch EvoIII 16g, Upgraded TMIC, APS hard turbo inlet, TurboXS catless uppipe/Downpipe->axleback joint, Prodrive axleback, DeatcshWorks 650cc injectors, stock BOV, GM Boost solenoid, SMC Meth injection with 70/30 meth/water mix, APS cold air intake with stock size MAF pipe
    What's different on my car since Scott's 358 hp and 368 tq tune? Well I'm now sporting a 6 speed so power isn't gonna be a concern (like it was before but hopefully Doug will make the car hit HARD now), going to a 44mm EWG, and going from a M7 meth nozzle to a M10 meth nozzle.
    Gonna be a close run between me and Daniel. I hope his tranny holds up! I'm interested to see if we break the 360 hp/370 tq mark but this is another dyno and the temps will most likely be diff. However I was told that SOG's old dyno was 1% within Topspeeds. Oh well we'll see!
  2. techlord
    As long as I do not forget I will swing by, gotta see what you put down as our setup is nearly identical less the FMIC.
  3. bsigari62
    bsigari62 Member
    Ahhh Help!
    i just got started with wrx atlanta and im having a hard time! can someone show me how i can make my new posts?
  4. FTZ
    Go into the Sub-forum you want to create a thread in. It will list all the recent threads in that forum. Towards the top, there should be a New Thread button.
  5. BKiller
    BKiller Active Member
    Sounds like a good day to come check out Topspeed and see some pulls...
    Brandon
  6. bsigari62
    bsigari62 Member
    how dude i get to the sub-forum?
  7. nsvwrx
    nsvwrx Active Member
    just go to the main forum page. and click any of the links.. like for sale or off topic
  8. slowwrx
    If you think you are going to make anywhere near the same power on topspeeds dyno you are going to be very disappointed.
    Matt
  9. Cool_____
    I'm expecting that Matt. I realize numbers are numbers. I'll get Doug to make a baseline pull and then tune the car to the best of it's ability. I want it to be a little aggressive yet safe.
    As far as what power numbers I make I'm basing what I make vs Daniel's. Daniel and I aren't in any type of competition but his turbo is nearly the same size as mine so we should both make within 5hp of each other.
  10. slowwrx
    I suspect you are probably going to read about 10 to 12 percent lower than what the SOG dyno read.
  11. Cool_____
    Really? Scott told me it was within 1%. I really don't care about the numbers. It's the improvement of the powerband.
    I told Scott to tune my car safely and he did just that with the taper. Now that I have a backup....I hope Doug will hold the boost more to make my tq shelf more flatter. It's the before and after plots that really matter.
  12. Cool_____
    Bump back up. Anyone doing anything Friday night next week? From what we can tell we should be rolling in the Topspeed area around 8-8:30ish Friday night. We gonna be hungry too!
    There a D&B near?
  13. ScoobyMike
    ScoobyMike OG Mod
    there's one in Marietta,GA and one in Gwinnett
  14. siegelracing
    The 353 whp from SoG's dyno is very appropriate for his 123mph trap speed.
    Siegel
  15. GTscoob
    I'll see if I cant get the day off of work and come hang out.
  16. Cool_____
    Thanks Scott....dunno why everyone doesn't believe anything that came from SOG's dyno with numbers.
  17. Kokopelli
    The reason people doubt it is because whenever there was a dyno day at Topspeed the people who had run on both dyno's put down lower numbers on Topspeeds dyno than SOG's.
  18. Cool_____
    Different day, different temps, different humidity, diff load, etc.....too many variables.
  19. jt money
    fixed that for ya. just to back that up thats what happened at the two dyno days i made at TS.
  20. siegelracing
    That's not entirely true. There were a number of my cars that dynoed great at TS - JohnyBoy - made more on TS's dyno than any Stg 2 WRX ever did on SoG's dyno...
    Siegel
  21. Kokopelli
    Did JohnnyBoy ever run on SOGs dyno with the exact same setup?
    It was the same reaction at the dyno day at Batlground.
    How much lower was Milo's on Batlgrounds than SOG's?
    There were quite a few that day that ran lower numbers too.
    I know its different dynos so I really wouldn't try to compare numbers as much as the change from the start of the tuning to the end.
    I am just relaying what I have personally seen as the differences.
    I would expect that with a more agressive tune you'll be around 360whp on Topspeeds dyno.
  22. Cool_____
    Lol as long as my car hauls azz more so now than it ever did on it's street tune I'm happy!
    LOL
  23. jt money
    thats all it really comes down to. :wiggle:
  24. Cool_____
    So I'm guessing there is nothing going on this Friday in the Topspeed area?
  25. techlord
    I am unable to get out Friday to play but plan on being there for the tuning session. Are you gonna be the first one tuned?
  26. Cool_____
    Dunno as that's up to Doug. Change in time....we gonna be there starting at 10AM. Also we are gonna be there about 3 hrs earlier on Friday.
  27. FTZ
    There is nothing specifically planned. I am sure we can find something to do that night. I will stop by TS after work.
  28. Cool_____
    Just want to specify that I was looking for something to do Friday night as we are heading home after the tune on Saturday!
  29. Cool_____
    Okay we are going to D&B tonight in Duluth. Should be there 9:30-10ish.
  30. FTZ
    Call me when you get in the area. I will come out.
  31. nsvwrx
    The D&B right near costco?
  32. Dante
    Dante Member
    Damn, too bad it's an hour away from me. I'm playing bachelor tonight and looking for something to do. :( What about Taco Mac at Perimeter Mall? Or are these set plans?
  33. Cool_____
    These are set now as we don't have a D&B anywhere near here.
  34. Cool_____
    Will do. We are coming down 85....about when do you want me to call?
  35. Cool_____
    All right guys we are hitting the road in 10 mins. Hope to see some of you either at D&B in Duluth or a the tuning session!
  36. jt money
    i was hoping to see this thread pop back up Sunday night or Monday and didn't so how did the tuning go Delette?
  37. FTZ
    I think he ended up with something like 342hp and 316tq
  38. jt money
    i was really looking to see how he liked the ewg after the tune. ie is he making peak boost faster... i wasn't trying to revamp that ts and sog dyno are very different again. lol
  39. Cool_____
    Sorry guys I went off on vacation in Asheville NC Sunday so I haven't been on. I'm on a very weak wifi connection in Asheville right now but I can say the car freaking SCREAMS. It pulls harder and stronger than it ever has. SOG dyno was indeed bogus....everyone says my car pulls sooooo much harder. Doug did a STANDUP job on my car and I'm 100% happy with it.
    Daniel with the Evo3 16g got 333 hp and 309 tq but I'm making almost 40 more hp and tq up top. We played on the way home and I jumped him 2-3 cars very hard instantly and I was shocked as I thought he was gonna make me work for it.
    I'll post up the dyno sheet later. I will say this though.....Doug told me himself that I am officially the strongest stock 2.0L EJ205 with 18g that he has tuned to date as is Daniel's Evo3 16g. Doug also said the car has 380ish hp on SOG's old dyno.....I believe it 100%.
    Doug if you read this thanks sooooo much for your time and work. Thanks for finding my bad coil pack, for tuning Daniel and Jason, and for working out the insane weirdness of Derek's bugeye. We all appreciate your time and work 100%. Oh and Derek's car is a beast for a stock turbo car ;) He made Jason work hard on the way home ;)
    I'll post the dyno sheet later. However if you read this Doug can you post the comparsion sheet of mine and Daniel's meth maps?
  40. Cool_____
    Peak boost is way faster on the street than before. On the dyno it looks the same but dang it climbs so freaking fast now that it has caught me off guard a few times. I haven't driven the car since Saturday and I'm itching to get home this coming Saturday just to drive the car.
