GoPro
Discussion in 'Modifications & DIY how-to' started by STIstorm, Aug 24, 2015.
  1. STIstorm
    STIstorm Supporting Member
    Just wanted to get an idea if any uses a go pro, and if you do; do you mount it in the car or on the outside and what mount do you use? I'm looking at the rubber magnet to mount mine on the out side. Is this a good idea or should I just keep it inside the car.
  2. LoveMyNewSoob
    LoveMyNewSoob Member
    I've mounted mine in MANY places on the outside with the suction cup mount that GoPro sells. It works really well and you can put it pretty much anywhere it will stick. I have had it on the track and down the dragon's tail with no issues. I think they rate it up to 100MPH or something like that.
