Got the Raytek Clone in.
Discussion in 'Modifications & DIY how-to' started by Genya, Sep 1, 2005.
  1. Genya
    AKA. A Laser thermo. WIll be comparing the engine temps of various area's before and after some of the cooling measures(Cermaic Coating ETC).
    Any Requests for temp readings?
    Any donor cars for some tmic temp testing? STi/WRX
    Jason
  2. GTscoob
    Sweeeeet
  3. Weapon
    I would liek to know the actual temperature of the air after the intercooler just before the intake manifold
  4. pEd
    I'd be cool with some TMIC testing. I'm on your neck of the woods as well, so let me know when the tests begin.
  5. scuby drew
    scuby drew techos ftws!!EEEE
    sounds like someone needs to buy my sti tmic and do a before and after install temp test
  6. Genya
    Sounds good, will get working on it, so far just playing with it, now time to start aquiring data. I will most likely start getting some temps at meets, before going in to eat and at cooldown.
  7. bambooi
    bambooi Member
    lol no wonder you kept playing w/ that thing
  8. Genya
    Yes Heat can be a killer.
    Need some ideas on how to uniform test.
    For intercoolers. End Tanks? Fins?
    Throttlebody, Intake Manifold, Radiator.
    Plus spots that arent hot but would show overall heat radiated, such as ??
    Airbox for stockers. Intake Pipe Temp. Belt Cover.
    Guess Ill start in an Excel Format. :)
  9. Brian
    Brian Active Member
    Sounds like a "cool" project. :keke:
    I still have my stock TMIC if you want to compare with it.
    I'm thinking about getting a tire temp gauge. It sticks into the tire and can help with alignment, driving style, etc.
    And does anyone have a damn G-Tech Pro!? I want to know my 0-60! :naughty:
  10. Genya
    Hehe!
    So far I have started some readings on some cars.
    Misc Interesting facts.
    Passenger side head is usually always hotter.
    Will eventually test ways to reduce the passenger side heat.
    May be coming from uppipe proximity to head.
    Testing is going like follows
    Right Head
    Left Head
    Air Intake Piping/Intercooler Piping/Airbox
    Heat Shield
    Compressor Side of turbo
    Header temp
    Center of intercooler
    Both Sides of endtanks
    Throttle Body
    Intake Manifold
    Top of Radiator
    I am attempting to gather cold, hot and 1hr cooldown temps.
    Looking for car with no heatshield and car with heatshield with the same intercooler.
    Anyone with a heat chimney.
    STi Topmount :)
  11. miloman
    at some point i would like to get the CO2 IC spray kit... curious how much of an improvement that would make
