JW if anyone could let me know how to take out the subaru emblem from the front grill? EX: Blue STi on the top of the page.
i just used a flathead screwdriver. i bent up the surround alittle trying to pry it off. just took my time and it eventually came off
Thanks yerrow but I meant the ENTIRE Emblem, not just the star sticker thing. Like the blue sub at the top of the page has nothing there at all, its just a plain grill with the little sti emblem on the corner. How do you do that?
cut your whole grill out then put in mesh grills and then stick a sti high sol sticker or emblem.. simple.. takes about 1 hour to do it nicely..
Paul Wall would be the best source for information on grills, they are even calling him george forman now bc he is selling everybody grills
Properly, you need to dremel that pillar out. Then sand down the grille piece to smooth so that you can repaint it and match the color. Remove the mesh prior to. Once the paint on the grill is dry, reapply the mesh to the back and voila, pillarless grill!
Does Paul Wall have a web site to let me see his grills? Auto Dreams here in kennesaw/marietta has the blank ones that look stock for like $80 which i thought was pretty good but if he can beat that then...
MAKE a custom grill.. will look sexy.. take ur stock grill and a driller then slowly cut the honeycomb grill peices then get ur self some grill's grill then stick it to ur stock grill peice then install it bak..
