Grounding kit
Discussion in 'Modifications & DIY how-to' started by moose, Jun 11, 2005.
  1. moose
    I just put in a grounding kit; hopefully it'll help smooth out higher RPMs a bit. So far, it might idle a little nicer than before, but I haven't had a chance to drive it and see if it really did make a difference higher up...
    I used these instructions: http://forums.nasioc.com/forums/showthread.php?t=674153&page=1&pp=25&highlight=ground+kit+gauge
    With a couple changes. I used one of the bolts that hold the A/C compressor to the alternator bracket instead of the alt. one (easier to get to, and they're very close), and I used one of the turbo bracket bolts to tie it into the passenger side head (again, easier to get to).
    Used 10 gauge wiring, eyelets, and heat shrink tubing. Soldered the shorter leads off the main wire. Looks pretty decent!
    -moose
  2. FTZ
    Post some pics. I would like to see how yours looks compared to my cheapo ebay grounding kit.
  3. moose
    I'll snap some later. Gotta go install some light fixtures.
  4. moose
    Well, I guess I'll snap 'em tomorrow since it's raining now. I did take it out for a longer drive, and it SEEMS to run smoother under WOT. Could be my imagination though! Either way, for a mod that cost me five bucks... who cares?
  5. SkullWRX
    SkullWRX Member
    Can I get someone to help me install my grounding kit? I started to do it this afternoon, got everything hooked in and went to turn it on...... voltage gauge read 9V instead of 12 before start, on ignition car went to 0V, no start... :grr: :crying: :eek4: So then the thunder starts, i quickly unwired every connection :ugh: I think it was just a bad connection point. I used 90% of the same ones as moose did above so I don't know what was wrong with it
  6. moose
    Doh. What did you connect it from and to?
  7. SkullWRX
    SkullWRX Member
    1)Neg terminal => driver cylinder bank, body earth (same point as voltage gauge), driver strut tower, passenger cylinder bank , alternator
    2)passenger cylinder bank => passenger strut tower
  8. SkullWRX
    SkullWRX Member
    oh, the collar that normally goes on the terminal for the voltage gauge was connected around the riser for the grounding kit.
  9. moose
    Where on the alternator did you connect it?
  10. 1ll-WRX
    i just bought a grounding kit but it also has a voltage stabilizer....does that make it any harder to do...never put one in...i'm sure it'll come with instructions...j/w
  11. SkullWRX
    SkullWRX Member
    that bolt to the left of the one shown on the nasioc post (the small 8mm one). shouldn't matter because the large one they use is attached to the same block as the small one i used...
  12. jt money
    shouldnt be any different. directions kinda suck. if you want i can show where i grounded all mine at.
