grounding or battery problem?
Discussion in 'Modifications & DIY how-to' started by WrxCrazy, Jun 18, 2006.
  1. WrxCrazy
    WrxCrazy Active Member
    okie i just got a new optima battery while bak and it runs great the first 2 weeks, then i got me a grounding sti kit, alex has that with no problems.. before installing the grounding kit, i was having o2 sensor problems, so i installed grounding kit by myself everything looked fine until BOOM car stoped working, when my headlights and cd player is on and i'm at idle my car just stops itself up shuts down everything thing and acts like it just got reset then i have to reset the clock, my TT etc etc.. also i have noticed my idle level is not 1k rpm anymore it's .500 rpm and am worried about whats gonna happen next cause everytime i'm idle it drains my battery and my car shuts down completely.. help.. what should i do? :hsugh:
  2. 1ll-WRX
    take off the grounding kit....and/or re-check that you grounded in the correct spots....a $20 ground kit isn't worth messing up your car....that's just the way it goes sometimes with ground kits....I installed a ground kit with another person...same grounds I started...he didn't....why, who knows..
  3. WrxCrazy
    i need a little detail on this
