Group-N/Beatrush/Cusco Engine Mounts
Discussion in 'Modifications & DIY how-to' started by calmnothing, Jun 12, 2008.
  1. calmnothing
    Sooooo I might have a little problem. My new header comes rediculously close to my sway bar. From what I've heard the Group-N engine mounts raise the engine slightly. Do the Beatrush and Cusco ones do the same? Or could I just reinforce the stock engine mounts to be stiffer?
  2. BrianGT
    The GroupN mounts don't raise the engine. The ones that I bought are the same as stock in terms of height. I probably can dig up pictures if you need some.
    You might be able to double up on the plates that go between the engine mount and the motor to get an extra 1/8" or so. I think I have spares if you want to try it.
  3. calmnothing
    I thought I remembered WJM saying that they did raise the engine.
