Happiness is going to a junk yard and finding everything you need on a car that is in better shape than your own. I spent a good hour trying to figure out why the car would even be in a junkyard and the next 2 getting everything I need.
no need. I now have a rack and pump. The car also still has an excellent windshield and all the body panels are perfect. I need to get a hold of Josh and see if he's interested in any other parts.
I'll get it from you if this one doesn't work. Between the two I should be able to rebuild one if I have to.
It was the Pull-A-Part on Bufford. They rarely have cars newer than 10 years old. Although I did once find a Silver 02 Wrx there so its always worth a shot. Check out www.pullapart.com for inventory. You can also set up alerts to be notified when cars you are interested in are dropped off. Very useful
so was it a wrx or an svx? i live 2 mins from there n can drop by to take peak if theres anythin i can use
Hehehe, I know. I'm right there with ya. I just figured that I needed to post since I haven't done so since we moved I MISS EVERYONE ***boohoohoosobsobsobboohoohoo***
