Headlight beam adjustment
Discussion in 'Modifications & DIY how-to' started by 1ll-WRX, Apr 11, 2006.
  1. 1ll-WRX
    Can anyone tell me how to adjust my headlight beam on my bugeye?...it's an aftermarket but very close to OEM.....thanks in advance...;)
  2. Suby1128
    Suby1128 Member
    if you pull out the headlight you should see a little attachment on the back with screws. You need to get a screw driver and twist one, so that the cog like wheels behind it turn. I'm not sure which way goes up and which goes down, in fact one of my headlight beams is messed up and I need to do the same for it.
    Craig
  3. bigb996
    to bad its not an sti scott they have a little switch in the cab...bastards
  4. 1ll-WRX
    ok that's what I thought that thing did.....not sure if that is functional on these.....it has the cog thingy but no way to turn it....and I could transfer the peice from my original but there's no place to screw it into the back?...I'll mess with it later.....Thanks for the help!!!!
  5. rolling_trip
    rolling_trip Active Member
    not sure, i just use the switch inside, hehe
  6. WrxCrazy
    WrxCrazy Active Member
    i have the same problem with my right side headlight it's kinda ez for oem but dunno abt aftermarket oem
