Hella supertones on a bugeye
Discussion in 'Modifications & DIY how-to' started by bigb996, Jun 21, 2006.
  1. bigb996
    anyone installed these on an 02? i took my grill off to put them on today and put them in and had fitment issues. Where did you mount them? not really any good places. Also how do you determine which is possitive and negative on the units themselves, they are not labeled.
  2. jonnyboy0150
    jonnyboy0150 Member
    Ive got them on my '02. What you do is extend the wire from the horn on the far driver's side. And you route the extension across to the center beside the other horn. As far as power and ground goes, it doesnt matter if im not mistaken.
    You can faintly see where they are on either side of the emblem...
    Ive been looking everywhere for the link to the website that helped me out and I finally found it! This site is badass! If you have any more questions let me know!
    http://homepage.mac.com/brianslick/supertones.html
  3. bigb996
    thanks a bunch john im gonna fix them tomorrow!~
  4. Deke
    Deke Active Member
    I've been curious about something, I know without modification the horns mount off-center (ones higher than the other), how hard is it to get them lined up, like most people have ended up doing?
  5. jakeisajedi
    jakeisajedi Member
    I have mine lined perfectly in the middle. You can just adjust them when you are tightning the bolts.
  6. Deke
    Deke Active Member
    alright, good stuff, thanks
  7. bluetwo
    bluetwo Active Member
    Yeah man. Hazzard just put some on his bugeye a couple o' weeks ago.
  8. Alex
    post up some pics brian when you get them in
  9. bigb996
    will do man
  10. jonnyboy0150
    jonnyboy0150 Member
    You are gonna love those things man! They are so much fun!!
  11. bigb996
    got them in just need to take pics hehe
  12. FTZ
    Make sure that when you wire them, both are wired the same way. It doesn't matter what is + or - as long as both are the same, if they are different, they may sound wierd. Same as a regular speaker.
