Just got a Blitz Turbo Timer the Boost/TT. I have it hooked in the ignition harness but the boost guage isn't hooked up. Not really planning on that but maybe cause I do need a Guage pod for my other one. But anyway Te car starts fine and the TT turns on and the auto settings start and run. But it does nothing when I turn my car off. The auto settings set for how long the car has been on not by the guage or the rev. Just wondering if I didn't cut a wire or didn;t hook something up.
hmm..did you splice or did you buy the adaptor harness. please say you got the adaptor. with the plug n play harness you should not have to splice anything (atleast for the TT part you might have to for the boost features). try to set it manually for 20 seconds and see if it will keep the car running for that long afterwards..if not you might have a problem with the unit or the harness
did you plug it into your e-Brake? If your car is shut off when the e-Brake is down, it just shuts off period. If you plug it correctly into the e-Brake then when the e-Brake is up and you turn your car off, it should begin the count down. I have the same set up, PM me if you need help. Craig
