HELP! boost issues
Discussion in 'Modifications & DIY how-to' started by midnight_rider, Nov 13, 2007.
  1. Ok heres the deal... Yesterday, as I was driving, the T fitting that I used to tap into the line for my boost gauge popped off. So I pulled over and put it back on. Then as I was accelerating my boost gauge read 22 psi before I even got to WOT. I have a stock turbo so this is way to high. I dont think it is the gauge because the vacuum sits at 15 which is where it is normally. I checked to make sure I didnt connect the fitting wrong and it looked fine . I do have a CEL but it was on prior to this happening. CEL codes are misfires. A co-worker of mine said it sounds like the wastegate isnt opening. I have no idea where to start. Anyone?
  2. Alex
    Maybe you hit boost creep?
  3. miloman
    I would reset the ECU and retry. This would let you know if the ECU learned something when the T was off. If that doesn't work, we could continue troubleshooting.
  4. I think it builds to 20+ psi much to fast to be boost creep but then again Ive never experienced it. It wasnt just one time either it is consistent. Ill try resetting the ecu and see if that doesnt fix the problem.
  5. miloman
    Are you tuned? If not, anyone remember what psi the stock ECU cuts boost at? I think it is well below 22. If so, your gauge may be off.
    Also, I'm not sure what you mean by 'the vacuum sits at 15 which is where it is normally'? Vacuum should be a negative number regardless of the units
  6. reset the ecu ( disconnect the positive terminal hold the brake for about 10 secs. correct?) no change
  7. no tune. I wasnt sure what the unit is for vacuum. -15 I suppose. heres a picture of what I mean....
    this is what it reads at idle
  8. CHEMSOLDIER27
    CHEMSOLDIER27 Member
    Disconnect the positive side then step on the brake to reset the ECU. The reattach the cable.
  9. miloman
    Could you take pictures of the T that came out? Zoomed in and zoomed out may be helpful.
  10. the side with the rubber band is the hose that leads to the gauge. rubber band there to hold it until I can get some clamps
  11. siegelracing
    Show a pic of the boost control. You have a line that is off that is preventing the wastegate from opening.
    Siegel
  12. is this what youre talking about?
  13. goixiz
    goixiz Active Member
    check from turbo to T fitting and to the union and the hose to the WG actuator
    make sure all is intact
    if all is good then your WG maybe stuck closed
  14. found the problem...the piece that the vacuum hose connects to on the wastegate actuator ripped clean off the WG actuator. anyone have an extra WG actuator for an 02 WRX?
  15. goixiz
    If you have an oversize TMIC it may be pressing on it and vibration and engine movement broke it off
  16. thats exactly what happened
  17. goixiz
    now as for fixing it
    I dont think its easy to locate just the WG but im sure its possible
    find someone with a bad turbo and willing to part it out.
    or for temporary find a fitting that you can thread into it and JBWELD it on till you find a replacement
    till then dont do any WOT runs :)
  18. siegelracing
    We've got one. $10 picked up.
    Siegel
