Well I tried to do a brake line install a while back and failed. The SubieTV install said to use a adjustable wrench to loosen the front line......big mistake and should have used a flare wrench. It rounded and I can't get the freaking thing off. I don't want to break anything so how can I fix this? Am I forced to cut and reflare the line or what? Any help is appreciated.
Also, you will want to hold the other end of the line. I had a pair of vise grips on both sides of the line to get mine done.
Lots of PB and vice grips with careful torquing did the trick. All 4 SS brake lines are now installed! THanks guys.
