help with vent smell
Discussion in 'Modifications & DIY how-to' started by Mad Mallard, Aug 23, 2005.
  1. Mad Mallard
    Mad Mallard the mad mallard
    thats right, something smells funky when the blower is turned on for the first time each day...
    ...but strangely not if the A/C is on... Anyone help of make suggestion?
  2. rolling_trip
    rolling_trip Active Member
    might want to start wiping when ur done, or flushing. JK hope u find it
  3. 1ll-WRX
    maybe it's time for a new cabin air filter?....the only thing i could think of :dunno
  4. Genya
    Check airbox/and cabin filter. Possible mold?
  5. miloman
    ive heard a lot of wrx's have this problem... ive been in someones rex and when the ac was turned on, it smelled like socks
  6. Alex
    It smells like all sorts of things. I dont really bother myself with it, almost every car has a smell to its A/C when it firrst kicks in.
  7. Goose013
    Goose013 Member
    mine stinks to high hell sometimes :barf: probably from all the Coke that spills into the vent from the upper cup holder. Not really sure though, thought I was alone on this issue.
  8. Weapon
    yea mine stinks when i first turn it on..but after that its fine..probably from air just standing still for some time without circulation..
  9. miloman
    anyone tried changing the filter?
  10. Mad Mallard
    how do i do dat?
  11. Weapon
    take out the glove box(I think its 4-5 screws) and to the lower right hand side you will see a white plastic box that has little clips..undo the clips and there is the filter..should take you all of 5-10 minutes to get to it
  12. gotsol
    gotsol Active Member
    mine stunk w/o the AC on because I left my indow down during arain storm.
    I changed the filter and bought some BG "Friggie Fresh" from SOG. that stuff works and smells so nice
  13. jonnyboy0150
    jonnyboy0150 Member
    Yeah i would also suggest some fridgie fresh, that stuff is indeed the shiznit! If your gonna change the cabin filter, you should spray some fridgie fresh down into the evaporator housing while you have it out. That stuff kills mold and whatever other crap that builds up makes your a/c reek.
  14. Mad Mallard
  15. jonnyboy0150
    jonnyboy0150 Member
    Im not sure how much a can of Fridgie Fresh costs, i would assume no more than 5 or 10 bucks though.
