Help!!.
Discussion in 'General Community' started by MarkM2016GTI, Feb 28, 2007.
  1. MarkM2016GTI
    I hope that this is in the right area, but I need to see if I could buy some bolts, or if anyone on the forums has some spare bolts for the Whiteline FS Bar. Mine are both missing!!:eek:hnoes: . I just noticed this the other day when I was getting an oil change. I am ordering the bushings through Whiteline, but I just need to get the bolts. Any help would be greatly appreciated....
    Mark
  2. bluetwo
    bluetwo Active Member
    Yikes! If I remember right I re-used my stock bolts on my FSB. I'm sure you could find the right bolts at Lowes or Home Depot if you look long enough... now whethey they'd be the right steel or not I couldn't say. They'd do in a pinch though.
  3. Greg
    Greg Active Member
    I'm not sure what size they are (14mm maybe...) but you could try Aircraft Spruce and Speciality, they sell military grade/grade 8 hardware...
  4. MarkM2016GTI
    Are they online?. Remember, I am in Hawaii now...
    Mark:)
  5. MarkM2016GTI
  6. Greg
    Greg Active Member
    They used to sell metric also... but I'm not seeing it. Is there a Subaru dealership close by?
  7. MarkM2016GTI
    Nope....the nearest one is in Oahu...Maybe I could call them...
    Mark
  8. Alex
    Prob best course of action unless there's a pepboy's near by.
  9. MarkM2016GTI
    We have Checkers here...That's about it...
    Mark
  10. goixiz
    goixiz Active Member
    which one are you missing
    the one between the swaybar and the endlink or the endlink to the control arm
  11. MarkM2016GTI
    I am actually missing 2....the ones that are between the swaybar and the endlink. Do you think that I should just go ahead and get after market endlinks?. I have Whiteline at present. I was also told to use Lock-Tite...Ped, did we use Lock-Tite after the bolts were put in?. I forgot...:eek:hnoes:
    Mark:)
  12. goixiz
    you need 10mm grade 8 bolts at least 50mm long
    for temp if you cant find 10mm then 3/8 is the closest
    ped uses VTEC paint :)
  13. MarkM2016GTI
    That's right...we used this yellow paint...Thanks Ming...
    Mark
  14. MarkM2016GTI
    So, are you saying a 3/8th inch bolt that is 50mm or longer will work right?.
    Mark
  15. Cool_____
    In a pinch it will but you need to located a metric bolt so there won't be any play. You don't want that wiggle or the sway will clunk and rattle like crazy. For the endlink question you had....if your stock front endlinks are metal no need to upgrade them.
  16. pEd
    Wait a minute Mark....
    What you're saying is that the endlink bolt is missing....
    Aren't you running the stock endlinks???? Is the stock endlink there?
    If you are, then you shouldn't be missing any bolts, maybe a nut that fits the endlink if anything.
    Also, what bushing are you ordering? When you purchased the sway bar it would've (or was supposed to come with upgraded bushings).
    If none of this makes any sense, can you take a pic and post it or email it to me?
  17. MarkM2016GTI
    Ped, both of the bolts from the front sway are gone...and the endlink on the right sway is pretty much deteriorated. I will take pics today or tomorrow when I am about to put on the new bolts that I am getting tonight. I have some buddies that are going to help me put the bolts back in. They have tools, etc. I am ordering Kartboy endlinks from www.oakos.com. I can get front and rear for 180.00 and free shipping to HI. That is what my friends recommended.
    Things are going great over here......except for this...I will get it all fixed...How is the new house doing PeD?.
    Mark
  18. pEd
    What I'm not understanding is this...
    The bolts and endlinks are one piece, unless the joint got ripped out of the endlink itself. There
    should be no bolts to replace. If anything, the only thing that may need to be replaced is the nut.
    (this only applies to the stock units, most aftermarket endlinks DO have bolts that can be lost).
    I don't understand how or what you buying a bolt is going to do for you.... on stock endlinks.
  19. goixiz
    wagon endlink is like a dogbone (plastic)
    and the bolts do come loose
    take a pic mark i think i know whats your prob
    and if your endlink does not have at least one end with sph bearings then you will have issues down the road. but maybe not with whiteline wagon specific FSB
  20. MarkM2016GTI
    Sorry for the confusion...I need to get the nuts.....not the bolts...I will take pics....
    Mark:hs:
  21. Greg
    Greg Active Member
    I was wondering the same thing :) The stud is part of the endlink
  22. goixiz
    hmm maybe the saabarus have a different front endlink
    pic of stock
  23. MarkM2016GTI
    I believe that does look different Ming...I am going to buy kartboys very soon anyways to replace the ones that came with the whitelines...
    Mark
  24. Cool_____
    Mark don't tell me you already lost your nuts after moving to Hawaii? :keke: J/K anyways if you replace those put a split washer on the inside of the nut...it'll keep it from backing back out.
  25. goixiz
    You should post a pic to let us see whats missing
    Are you sure its different ? i thought all wagons have similar front and rear endlinks
    but maybe because its because its 2006
  26. MarkM2016GTI
    Problem solved...Pics coming soon...
    Mark
  27. 1ll-WRX
    sweet, glad to hear it man...hopefully didn't cost you much
