HKS exhaust question?
Discussion in 'Modifications & DIY how-to' started by bjtyson3, Feb 6, 2007.
  1. bjtyson3
    bjtyson3 Member
    i was told that an HKS HI-Power exhaust for an STi was made for an sti with an aftermarket downpipe,but the hks site says nothing about it..anyone know the truth?
  2. Alex
    Whats the difference? If you're using a US spec'd DP there shouldnt be an issue between stock and aftermarket. They're the same length unless you're buying a shorty DP. Perhaps that's what it is implying, however, Ive never heard of this. Im fairly certain Brian uses one, be sure to send him a PM!
  3. clemsonscooby
    clemsonscooby Active Member
    Sti and WRX catbacks are the same. Same with the downpipes. You don't want to go with the HKS downpipe though. Its not the best design, since it still uses a flat plate like stock behind the wastegate. This will decrease the flow of the wastegate. Go with a bellmouth or divorced wastegate pipe design (Maddad, Perrin, Invidia, B&B, etc...). The downpipe does not come with the catback.
  4. Deke
    Deke Active Member
    Simply, it shouldn't be a problem with the stock downpipe.
