Holy cold weather + wastegate arm adjustment
Discussion in 'Modifications & DIY how-to' started by Davidwrx, Nov 19, 2008.
  1. Davidwrx
    Davidwrx Member
    In an alignment of the stars I adjusted my wastegate actuator arm. That combined with the weather this morning the car felt great! I went from Cobb Stage 2 (93) around 14.7 psi max to right at the target 15.8 psi. I went 2 1/2 turns on the arm. It was easy as my turbo heat shield only has 3 bolts after I went stage 2.
    Don't know which had more effect. Guess I will see when it warms up.
  2. Alex
    Weather perhaps, I am sure it feels great though.
  3. UpSideDownDesi
    UpSideDownDesi Active Member
    cold weather mmm mmm good.
