For all ya bored folks out there.... Like any red-blooded, masculine man of the male gender, I love PVC weaponry. You should too. If the concept of heading on down to the local Home Depot and transforming $100 worth of random pipe bits into a killing machine doesn�t appeal to you, you�re a frikkin' pansy. Also, you�re probably sane and will live significantly longer than I will. Nonetheless you disgust me, and I take comfort in the knowledge that your obituary will be nowhere near as humorous as mine. For those of you who laugh in the face of hypersonic shards of plastic puncturing your spleen, here�s an intimate look at how I�ve kept myself busy for the past week: building a PVC flamethrower. If you're not interested in the building process, skip to the bottom of the post for the fire. My flamethrower has two main parts, a gun/hose assembly, and the tank. I made the gun first: http://img10.imageshack.us/img10/8243/1-gun.jpg It�s made entirely of parts you can get at your average hardware store. The hose connects to a stop valve, which connects to a short pipe nipple that's tapped directly into the tank. http://img40.imageshack.us/img40/4795/2-valve.jpg The tank took a while to make, because I let each set of chemical welds dry before doing the next ones. The ends of the tank are two 90 deg. elbows and two 90 deg. street elbows, welded to make two full 180 deg. "U"s. One side of the tank is a 2' length of 4" sch.40 PVC, the other is a 4"x4"x1.5" T with standard pipe attached to each 4� socket. http://img28.imageshack.us/img28/8075/3-pipes.jpg Before assembling the parts, I drilled and threaded the two holes I needed in the tank ends: a 1/4" standard pipe hole for the outlet to the hose, and a 1/8" standard pipe hole for the valve that I would use to pressurize the tank. Interesting note: 1/4" and 1/8" pipes have no actual relation to the measurements of distance commonly known as the quarter inch and eighth inch. The holes are actually 7/16" and 11/32" respectively. Hooray for non-metric measurements. http://img40.imageshack.us/img40/6082/4-drill.jpg http://img40.imageshack.us/img40/9984/6-tapping.jpg http://img40.imageshack.us/img40/16...ppedthreads.jpg Next step: cement one end of the tank: http://img40.imageshack.us/img40/759/8-weld1.jpg Then the other: http://img40.imageshack.us/img40/2388/9-weld2.jpg After the tank dried, I dredged up an old camping backpack to hold it. I cut a hole in the bottom of the pack and screwed the gun/hose assembly into the base of the tank. http://img40.imageshack.us/img40/8640/10-backpack.jpg Finally, I screwed in the Schrader valve (which I bought from www.spudtech.com, an excellent online retailer for PVC weapons and parts) to complete the tank: http://img18.imageshack.us/img18/3293/11-svalve.jpg Now the whole rig was ready for some pressure testing. Since I would soon be running the distinct risk of giving myself heat-assisted, deep tissue exfoliation, I was extra-careful to make sure there weren't any leaks. I used up a lot of Teflon tape. http://img18.imageshack.us/img18/7053/12-tapedcap.jpg And, after filling the tank with water for a trial run, made sure the cleanout cap was on nice and tight http://img27.imageshack.us/img27/9522/13-tightcap.jpg before flipping on the air compressor. http://img27.imageshack.us/img27/8950/14-pressurize.jpg No leaks! At this point, I had quite possibly the world's most kick-ass super-soaker. http://img27.imageshack.us/img27/4641/15-test1.jpg http://img27.imageshack.us/img27/9643/16-test2.jpg Of course, I didn't go through all that effort for a damn squirt gun. So I added a pilot light in the form of a blow torch. http://img27.imageshack.us/img27/1951/17-torch.jpg Much better! The finished product: http://img27.imageshack.us/img27/91...hedproduct1.jpg http://img27.imageshack.us/img27/90...hedproduct2.jpg http://img27.imageshack.us/img27/55...hedproduct3.jpg There was only one thing left. Add some fuel (denatured alcohol; PVC is soluble in gasoline) http://img27.imageshack.us/img27/6721/21-fuel.jpg And TURN UP THE HEAT. I accidentally set my camera to long exposure, so some of the pics look blurry. It worked out well for capturing the flames, though.
yea..thats some hard core shit..i remember reading/watching somewhere that the military doesnt use flamethrowers anymore because they are so dangerous..
hell yeah!! you're insane. the only pvc stuff I've made is the potato cannon, which is just fine for now.
dude, never made a potatoe gun? this is the next logical step! or actually...how bout a flaming potatoe gun? oooh, how would one do that, oil up the potatoe?
